Alpine IDA-X200 $100 shipped
Kangaroux
I put on
Condition: 9.5/10 (minor chipping around the rotary wheel)
Functionality: *10/10 (* see below for details)
This headunit works great with ipods and usb drives. Comes with 3x 2v preouts, rear USB and has the capability of using AUX if you get the adapter. The headunit features a large rotary wheel which makes scrolling very easy. If you plan on using an ipod with this headunit I highly suggest using an older ipod (ipod classics, ipod video, ipod nano, etc). Newer itouches and iphones are a bit glitchy and will occasionally skip.
$100 shipped firm, no trades
USPS flat rate. NOTE THIS HEADUNIT DOES NOT COME WITH A HARNESS. The harness I have is cut down a ton and is very hard to work with because the wires are short. You can find a new harness online for around 10 bucks
Comes with a HPF for the speakers, does not include crossovers for the sub but does include a dedicated sub level (the sub level isn't a bass boost it just affects the subwoofer preout voltage).
Iirc if you want all of the fancy crossovers you need the alpine power pack but I'm not positive because I don't have one
This has HPF and Highs/Lows two band adjustable parametric eq which is actually nice for a 2 band. The deck sounds awesome and has sub attenuation and a good amount of settings such as date and calendar. It doesnt have a pretty face really, but it does sound good. Has 24 bit d/a converter. I had this deck prior to Mr. ROO and it always did justice.
Also it's imprint you want not the power pack haha. iPod works through usb, but is better with full speed and you can get one of those cables for 10 bucks on ebay iirc
Kangaroux
I put on
Kangaroux
Maine
Kangaroux
