Sold Alpine #F1 CDA 7990 and H900
headshok
Hi all,
i got an old Alpine #F1 CDA 7990 + H900.
This set works perfectly and is in 9/10 condition.
The H900 processor was custom sprayed black to suit the install.
Price is at 3100 USD Shipped to your door step via international EMS ( courier services)
If you wish to buy the processor or HU seperately,
processor will be $1990 USD shipped and the HU will be 1250 shipped.
As for refs,
i have my own section over at CACO
http://www.caraudioclassifieds.org/forum/forumdisplay.php?f=127
and here's an introduction of myself
http://www.caraudioclassifieds.org/forum/showthread.php?t=13203
PM or email me at wrussel@gmail.com
payment will be through paypal
Thanks guys
Cheers
I am looking for just the h900. do you have the box and remote? Can we work a deal? I think your price is a bit high because it is not in original condition. Would you consider some trades? I deal in only High end gear so I would not insult you by offering JL and such.
$3000 ? Is it that much better than the other high end audiophile units such as DRZ9255 ??? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
specs dont show $3000...
Number of bands: [front] 31, [rear] 31,
31 and [sub-woofer] 10 ● Graphic EQ boost cut range: ±9 dB ● Time correction control range: 0-20 ms (0.1 ms increments) ● Frequency characteristics: 20 Hz-20 kHz ● SN ratio: 110 dB ● Channel separation: 80 dB ● Input sensitivity: >850 mA (2V for analog 1 only) ● Sub-woofer crossover: 50-200 Hz (1/6 octave increments) ● Sub-woofer level control: 0 dB to + 15 dB ● Rated output: 4V (with 10k ohms load) ● Input impedance: 10k ohms or lower ● Output impedance: 1k ohms or lower ● External dimensions: Display: 170W x 46D x 24.6H mm ● Remote controller: 14.47W x 80D x 30.7H mm ● Base unit: 325W x 280D x 69H mm ● Weight: Display: 18g ● Remote controller: 14g (without batteries) ● Base unit: 5.1 kg.
In a nutshell, yes. ODR aside the H900 is the absolute finest processor ever produced.
$3000 is also the owners asking price. When new and current full SRP was $4100 and the 7990 was somewhere around 1500 IIRC. Most H900s alone fetch between 1800 and 2800 is good condition and working controller.
headshok
headshok
Singapore
JKashat
