Alpine CDA-9887 Manual Posted
Props to Mach Y for all this info.
Some info from the manual:
When using MultEQ, MX, X-OVER, T.Correction, User’s EQ,
Parametric EQ and Graphic EQ are set automatically. They are no
longer user adjustable.
Ok, that blows. Basically, if you use the Odyssey sound system to automatically level your car, you cannot tweak it AT ALL after that. To do any manual tweaking, the Odyssey MultEQ must be completely turned off
If you do turn off MultEQ, you can do the following:
7 band graphic eq, freqs are fixed:
Band-1 (63 Hz) / Band-2 (150 Hz) / Band-3 (400 Hz) /
Band-4 (1 kHz) / Band-5 (2.5 kHz) / Band-6 (6.3 kHz) /
Band-7 (17.5 kHz)
5 band para eq, freqs are adjustable in 1/3 octave increments for all 5 bands, from 20Hz to 20kHz, with +/-6dB on each, and a width of 1, 1.5, or 3.
The crossover section can be set to:
2.2ch (3WAY) System / L=R
Setting items:
LOW / MID-L / MID-H / HIGH
2.2ch (3WAY) System / L /R
Setting items:
LOW-L / LOW-R / MID-L-L / MID-L-R / MID-H-L / MID-H-R /
HIGH-L / HIGH-R
Setting items:
LOW / MID-L 20 Hz~200 Hz
MID-H 20 Hz~20 kHz
HIGH (1 kHz~20 kHz)
Adjustable slope: FLAT, 6 dB/oct., 12 dB/oct., 18 dB/oct.,
24 dB/oct
Adjustable output level: –12 to 0 dB
4.2ch (F/R/Sub-W) System / L=R
Setting items:
LOW / MID / HIGH
4.2ch (F/R/Sub-W) System / L /R
Setting items:
LOW-L / LOW-R / MID-L / MID-R / HIGH-L / HIGH-R
Time Delay goes from 0-99ms (0 - 132.7 inches)
Specifications
Tuning Range 87.5-108.0 MHz
Mono Usable Sensitivity 0.7 μV
Alternate Channel Selectivity 80 dB
Signal-to-Noise Ratio 65 dB
Stereo Separation 35 dB
Capture Ratio 2.0 dB
Tuning Range 531-1,602 kHz
Sensitivity (IEC Standard) 25.1 μV/28 dB
Tuning Range 153-281 kHz
Sensitivity (IEC Standard) 31.6 μV/30 dB
Frequency Response 5-20,000 Hz (±1 dB)
Wow & Flutter (% WRMS) Below measurable limits
Total Harmonic Distortion 0.008% (at 1 kHz)
Dynamic Range 95 dB (at 1 kHz)
Signal-to-Noise Ratio 105 dB
Channel Separation 85 dB (at 1 kHz)
Wave length 795 nm
Laser power CLASS I
Power Requirement 14.4 V DC
(11-16 V allowable)
Maximum Power Output 60 W × 4
Maximum Pre-Output Voltage 4 V/10 k ohms
Bass +20/–14 dB at 60 Hz
Treble ±14 dB at 10 kHz
Weight 1.7 kg (3 lbs. 11 oz)
genxx
Team JL Audio
genxx
Oklahoma
genxx
