Alpine CDA-9886 w/aux cable and remote
ALL4SPL
Graphics Guy
Alpine CDA-9886 with ai-net aux cable, usb extension cable and remote, no trim ring however can be purchased at pacparts.com for $5.
Shows wear on the main chicklets, the screen has no scratches.
Alpine Electronics of America, Inc.
$165 shipped USPS priority mail with insurance.
Full specs;
Features and Specification
SPECIFICATIONS
CEA-2006 Power Ratings
CEA-2006 Power Rating: 4 I? @14.4V Ƈ%THD+N, S/N 80dBA (ref.1W into 4 I?), 18W x 4
Max Power Output Ratings
Max Power Output: 50W x 4
FM Tuner
Tuning Range: 87.7-107.9 MHz
Mono Usable Sensitivity: 9.3dBf (0.8 A?V/75 ohms)
50dB Quieting Sensitivity: 13.5dBf (1.3 A?V/75 ohms)
Alternate Channel Selectivity: 80.0 dB
Signal-to-Noise (S/N) Ratio: 65.0 dB
Stereo Separation: 35.0 dB
Capture Ratio: 2.0 dB
AM Tuner
Tuning Range: 530-1,710kHz
Usable Sensitivity (IEC Standard): 22.5/27.0 (A?V/dBf)
Disc Player
Frequency Response: 5-20k A?1 dB
Channel Separation (at 1kHz): 85dB (at 1kHz)
Dynamic Range (at 1kHz): 95 dB
Total Harmonic Distortion (at 1kHz): 0.008% (at 1kHz)
DAC Type: 24-Bit DSP with integrated DAC
Wow & Flutter (%WRMS): B.M.L.
Oversampling: 8x/352.8kHz
Signal-to-Noise Ratio: 105 dB
Connection for iPodA?
MP3 Decoding: MPEG-1/2 AUDIO Layer-3
WMA Decoding: Windows Media' Audio
AAC Decoding: ACC-LC format ''/m4a'' file
Number of Channels: 2-Channel (Stereo)
Sound Tuning
Subwoofer Level Adjustment: -15dB to 0dB (1dB steps)
Bass Level Control Range: A?14dB at 100Hz
Bass Center Frequency: 60/80/100/200Hz (Selectable)
Bass Band Width Adjustment (Q): 4 choices (1 =narrow, 4 =wide)
Treble Level Control Range: A?14dB at 10kHz
Treble Center Frequency: 10k/12.5k/15k/17.5kHz (Selectable)
MediaXpander Modes: FM, CD, XM, MP3, (Level 1, 2, 3, Off), DVD Video (Level 1, 2, Off), DVD Music (Level 1, Off), (PXA-H100 Required)
MediaXpander Aux Settings: MP3, Music, Movie, (Level 1, Off), (PXA-H100 Required)
Equalizer: 5 Band Parametric (20Hz - 20KHz, 1/3 oct. Steps), 7 Band Graphic, (PXA-H100 Required)
Time Correction: Adjustable 6 Ch. Time Correction (L-F/R-F/L-R/R-R/L-SW/R-SW), (PXA-H100 Required)
Crossover: High Pass: 80/120/160Hz (Selectable)
IMPRINT: IMPRINT Sound System Ready (PXA-H100 Required)
Remote Control
Remote Control: Included
Model Number: RUE-4202
Battery Type: AAA Batteries (2 pcs.)
Dimension (WxHxD) mm : 42mm x 121mm x 23mm
Dimension (WxHxD) in : 1-21/32'' x 4-25/32'' x 29/32''
Weight: 1.5kg (3lbs. 4oz.)
Dimensions
Din Size: 1
Chassis Size (W x H x D) mm: 178mm x 50mm x 160mm
Chassis Size (W x H x D) in: 7'' x 2'' x 6-1/4''
Nose Piece Size (W x H x D) mm: 170mm x 46mm x 24mm
Nose Piece Size (W x H x D) in: 6-3/4'' x 1-13/16'' x 15/16''
General
Power Requirement: Power Requirement: 14.4 (11-16) V.DC
Pre Output Voltage (Before Clipping): 4V
Operating Temperature (A?C/ A?F): 60 A?C (140 A?F) to -10 A?C (14 A?F)
Maximum Mounting Angle: 35A? from Horizontal
Weight: 1.6kg (3lbs 8oz)
FEATURES
Tuner
Memory Presets: Preset Stations (FM:12/AM:6)
Memory: Auto
Seek Mode: Local/DX Selection
HD RadioA?
Built-In or Ready: HD Radio Ready
Connection: Alpine TUA-T500HD Required
Status Indicator: HD Radio Satus Indicator
Signal Switching: Automatic Digital/Analog
Multi-Casting: Multi-Cast HD1, HD2, HD3
BluetoothA?
Parrot Bluetooth Module Built-In: Bluetooth Ready
Connection: Alpine KCE-300BT Required. Features may differ between phone model and service providers.
Hands Free: Hands Free Calling
Phone Book: Phone Book Transfer
Streaming Music: Streaming Music Playback
Streaming Music Control: Streaming Music Control
Connection Type: Full Speed Connection for iPodA?
Connection for USB: Dedicated iPod Source
Connection: Full Speed Cable Included (KCE-422i)
Compatibility for iPodA?/iPhoneA?: Full Speed Connection: iPhone, 4th/5th Gen. iPod Video/Photo, iPod mini, iPod nano and iPod touch
M.I.X. (Shuffle) Capability: Song, Albums, All
Music Control: Song Up/Down/Repeat
Available Selections: Playlist, Artist, Album, Song, Podcast, Genre, Composer, Audiobook
Percentage Search: Percentage Search
Information Display: Artist, Song, Album
Easy Navigating: Quick Search
Satellite Radio
Built-In or Ready: Satellite Radio Ready
Connection: SIRIUS or XM Adapter Required
Satellite Provider Capability: SIRIUS or XM
Preset Memory: 3-Bands (6 Per Band, 18 Channels Total)
Easy Navigating : Quick Search
Music Information: Category, Artist, Song
Portable Compatibility: SIRIUSPlug N Play Devices (Adapter Required)
Disc Player
Disc Type: CD Player
Disc Playback Type: CD/CD-R/CD-RW
Music Playback: MP3/AAC/WMA Playback
DAC: 24-Bit DSP with integrated DAC
Zero data Mute: 0 Bit Mute
Digital Servo: Digtal Servo
Music Sensor: Scan/Repeat
Playback Control: Play/Pause/Forward/Back
M.I.X. Mode: One (Folder)/All (Random Play)/Random (CD Only)
Sound Tuning
Subwoofer Level: Subwoofer Level Adjustment
Equalizer: 5 Band Graphic / 7 Band Parametric Equilizer Ready (PXA-H100 Required)
Bass Level: Bass Level Adjustment
Bass Center Frequency: Bass Center Frequency Adjustment
Bass Bandwidth Adjustment: EQ Width Adjustment
Treble Level: Treble Level Adjustment
Treble Center Frequency: Treble Center Frequency Adjustment
Loudness: Loud Feature
MediaXpander: MediaXpander Ready (PXA-H100 Required)
Time Correction: 6 Channel Time Correction Ready (PXA-H100 Required)
Crossover: High Pass Filter Adjustment
CD Changer Control
M.I.X.: One/All (Shuffle)
Multi-Changer Control: Multi-Changer Control including MP3 Changer CHA-S634 (with KCA-410C)
Music Text Information: CD:Text Scroll Display, MP3: Text Information Display (ID3 Tag)
Music Control: Play/Pause/Forward/Back
Repeat: Song/Disc
General
Power Output: 50W x 4 High Power Amplifier
CD Changer: CD Changer Control
Display: 2 Color Biolite Display
Control Type: Rotary Encoder Knob
Face Color: Gunmetal Black
Illumination Buttons: Blue
USB Input: USB (1.1/2.0) Input (Mass Storage Class)
PreOut: 3 PreOut
BluetoothA?: Bluetooth Ready
Auxiliary Input: Versatile-Link Ready (KCA-121B Auxiliary Input)
Steering Wheel Control: Steering Wheel Control Ready
Selectable Power Input: 2 PreIn (Front/Rear)
Bass & Treble: Bass & Treble Controls
Fader & Balance: Fader & Balance Controls
Clock: Built-In Clock
DIN Trim Plate: Detachable Trim Plate
Detachable Face Plate: Detachable Face Plate
Dimmer: Dimmer Input
Power Antenna Lead: Power Antenna Output
Remote Turn-On: Amplifier Remote Turn-On Output
Audio Interrupt: Audio Interrupt Input
Mute: Built-in Audio Mute
Remote Control: Remote Control Included
yeah but i have an ipod touch 4th gen and it doesnt work on my Alpine cda-9886 same exact cd player, i called alpine they said that no only older ipods work, so no the 4th gen and 5th gen touch DOES NOT work on this cd player! .... im not exactly sure how old your ipod has to be to use on this cd player, but its really pretty shatty if you ask me!..i have a 50 dollar sony in my 2nd truck that i can use any mp3,ipod, cell phone that i want through the AUX or USB, but not on this pricey expensive cd player! ....so i would have to say i like my pos 50 dolla sony way better! even though the alpine looks cool, and of course alpines have the most complicated menus of any cd player out there!
Actually using the AUX cable this unit does not control the ipod but will play it, meaning you have to control the ipod itself but it will still play. For FULL ipod control a newer unit would be needed.
idk bro, me personallyi prefer to use the ipod its self for controll, even this doesnt work on mine, when i called alpine he had me do a hard reboot of the cd player then it worked , next time i got in my truck it didnt, so i did the same reboot still didnt work, i tried about 10 times since then but only worked like 2 times so i gave up on it!...pretty crappy really since its such a **** head unit!
didnt know Se*y was a bad workd! hhmm
Well sorry you had bad luck I have ran Alpine for a LONG time, and never had any issues. I only switched to Pioneer since Alpine got out of the High End single din units. They even make a full control cable for this unit for $10 on ebay, however it is limited to certain ipods.
ALL4SPL
Graphics Guy
ALL4SPL
Orlando, FL
momax_powers
