Alpine CDA-9847 or Pioneer DEH-P670MP????
I have a 4 channel amp with 4 speakers. I will add subs with a second amp later on. I need 3 sets of RCA's , I do not want CD's to skip. I would like to set my subs right from the head unit. I dont know ask me a few questions
you've done good to get to these two. The pioneer has a remote, the alpine has a little better S/N ratio. The pioneer has a better on-board amp, which you don't need. I'm not a fan of the alpine bass-engine, but it DOES have iPod controls built in. The pioneer specs non-fading sub output, I don't know about the alpine's.
you do know SE isn't authorized dealers for these, right? the ONLY warranty is through SE. The pioneer has a 2 year the alpine a 1 year.
Do you mean you would like to adjust your amps from the HU? If so, I would go with an Alpine. However, you will need to go with a higher end model to take advantage of the AI-Net feature. About 150 dollars in AI-Net cables will allow you to make all the amp adjustments right from the HUwithout going into the trunk.
It is a nifty feature. Just a thought.
Do you mean you would like to adjust your amps from the HU? If so, I would go with an Alpine. However, you will need to go with a higher end model to take advantage of the AI-Net feature. About 150 dollars in AI-Net cables will allow you to make all the amp adjustments right from the HUwithout going into the trunk.It is a nifty feature. Just a thought.
that is IF you have Alpine amps, right? pretty cool.
paintballproam
Hey i can change this
paintballproam
troy nh
djman37
