alpine is real nice,only little smudge on the volume knob.comes with head unit,faceplate,all wiring.came with a sleeve,but its a pioneer.you can have it if you want.$75 shipped
http://www.crutchfield.com/S-XuA8ZPJu1DQ/p_500CDA9805/Alpine-CDA-9805.html
•detachable face
•MaxTune tuner
•12 FM/6 AM presets
•Bass Engine (bass center frequency, width, and level, plus treble center frequency and level adjustments)
•Media Xpander
•XM Satellite Radio controls (XM Radio subscription, tuner, antenna required to receive the satellite radio signal.) — service is available only in the lower 48 states, not available in Alaska, Hawaii, or U.S. territories
•CD changer controls for Alpine Ai-NET changers only
•optional auxiliary input
•MOSFET internal amp
•4-volt front and rear preamp outputs
•4-volt subwoofer preamp outputs
•clock
•23 watts RMS/50 peak x 4 channels
•CD frequency response 5-20,000 Hz
•CD signal-to-noise ratio 105 dB
•FM sensitivity 9.3 dBf
•1-year warranty
kenwood is in pretty good shape.det.face and have the case.no trim ring or anything else.has a short harness.$75 shipped
http://www.crutchfield.com/p_113KGC9044/Kenwood-KGC-9044.html?search=KGC9044&tp=116
•detachable face
•11-band equalizer, 12 dB boost or cut for each band
•11-band multicolor spectrum analyzer display with white LED backlight
•3 sets of gold-plated 4 volt preamp outputs: front, rear, and non-fading
•6 factory-preset EQ curves
•3 user-programmable EQ curves
•display contrast and dimmer adjustment
•low-pass electronic crossover (50/80/120 Hz)
•high-pass electronic crossover (40/60/80/120/150/180/220 Hz)
•signal-to-noise ratio 88 dB
•THD 0.01%
•7-3/16"W x 2-1/8"H x 6-11/16"D
pm with any questions,NO TRADES AT THIS TIME.
•detachable face
•MaxTune tuner
•12 FM/6 AM presets
•Media Xpander
•clock
•1-year warranty
•detachable face
•THD 0.01%
