Alpine cda 7998 and alpine 12 disc cd changer
Polski13
MI
Alpine cda 7998 head unit
And
Alpine 12 disc cd changer
Cda 7998
8/10 cosmetically because some button lettering has slight wear, the trim ring has broken tabs. 10/10 mechanically. Unit has been bench tested for power and all face functions.
Remote, wiring harness, cage, trim ring, original manual included. I don't have the original box.
Features
FantomFace XL motorized stealth faceplate
BioLite high-resolution display
switchable green or amber button illumination
plays MP3 files on CD-R or CD-RW, plus audio CDs, CD-Rs, and CD-RWs
MaxTune SQ tuner
XM Satellite Radio controls (XM Radio subscription, tuner, antenna required to receive the satellite radio signal.) — service is available only in the lower 48 states, not available in Alaska, Hawaii, or U.S. territories
Bass Engine Pro (5-band parametric EQ, 6-channel digital time correction, 6-position crossover with variable slope, plus subwoofer phase and level controls)
Media Xpander
CD changer controls for Alpine Ai-NET changers only
optional auxiliary input
premium-quality power supply and output capacitors
gold-plated 4-volt front, rear, and subwoofer preamp outputs
i-Personalize
clock
wireless remote
component amp(s) required — no internal amp
CD frequency response 5-20,000 Hz
CD signal-to-noise ratio 105 dB
FM sensitivity 9.3 dBf
Cd changer
7/10 cosmetically because theres a slight crack in the upper right hand corner. Other than that, the changer has never been used. I never got the chance to install it.
Accessories/ hardware and screen for sliding door included.
400 obo
Buyer pays
Is the case cracked on the right side of the cd player ? would you separate the two ?
Yeah it is, you can see the crack in the pic. I may consider seperating, but it wouldn't lower my price by too much
Polski13
Polski13
MI
Polski13
