Sold Alpine CDA-7892 and Crossfire VR705D
Shinju
Selling a used but in very good working and cosmedic condition CDA-7892. This is one of the better if not one of the top SQ decks that Alpine has made.
Comes with everything but the mounting Cage it was mounted ISO in the original owners car.
It does have some button wear on the presets 1-3 but other then that its a solid 8.5/10 Mind you this deck was made in 2002 it will not play MP3's but it will play CDDA/Audio file Burnt CD-r's.
The secret to the CDA-7892's outstanding sound is simple: Alpine's Media Xpander™. This amazing feature can re-energize all your music — CDs, radio, external sources — with the press of a button.
The Media Xpander will also enhance the crystal-clear sound of XM Satellite Radio — add an Alpine XM tuner and antenna and subscribe to XM's over 100 channels of digital music and entertainment for only $9.99 a month.
Alpine's got your AM/FM radio needs covered with their super-sensitive MaxTune SQ tuner. 18 presets give you plenty of storage for your favorite stations.
Bass Engine® Plus is beefed up with 4-channel digital time correction, so you can fine-tune the stereo imaging with pinpoint accuracy. A 3-position, 12 dB/octave crossover is also included. It lets you split the lows from the mids and highs when you connect Alpine component amps and subwoofers to the front, rear, and subwoofer preamp outputs.
A wireless remote is supplied for convenience.
Details:
•motorized, detachable face
•MaxTune SQ tuner
•Bass Engine Plus (bass center frequency, width, and level, plus treble center frequency and level adjustments, as well as 4-channel digital time alignment and a 3-position, 12dB/octave crossover)
•Media Xpander
•plays audio CDs, CD-Rs, and CD-RWs
•CD changer controls for Alpine Ai-NET changers only — add an Alpine changer to your receiver order, and save $$ with Crutchfield's package discount
•XM Satellite Radio controls (tuner, antenna, and subscription required)
•optional auxiliary input
•4 volt front, rear, and subwoofer preamp outputs
•clock
•wireless remote
•20 watts RMS/50 watts peak x 4 channels
•CD frequency response 5-20,000 Hz
•CD signal-to-noise ratio 105 dB
•FM sensitivity 9.3 dBf
Asking 135.00 shipped.
Next up is a Crossfire VR705D 5 channel amplifier Amp is in good condition with some scratches here and there. And works awesome, Very powerfull and Underrated 5 channel Amp.
This amp has never been taken apart still has the crossfire warranty seal unbroken.
Here is the bad, The amp is missing the front, Rear and Powersupply Plugs. I use the ones from my VR404d to test this and it works but You will need to find speaker/power or sub plug/plugs for it it does come with the sub/power (they are the same size)
I do believe the newer PPI PCX plugs are the same size and will work you can get a 4 channel set for around 40 bones off ebay or less. I have tried to contact Crossfire to see if they have any extra sets but no luck getting anyone to call me back.
Amp has been tested and works with in its rated ohm load no further warranties or returns are implied, amplifier will not be DOA.
5 channel hybrid amplifier
Output Power at 12.5V:
4 x 50W + 1 x 150W @ 4 ohms
4 x 100W + 1 x 300W @ 2 ohms
2 x 200W @ 4 ohms bridged
1 x 500w @ 4ohm Sub Channel
THD: 0.02%
Bandwidth: 5Hz ∼ 38kHz / 5Hz ∼ 250Hz (+3 dB)
S/N Ratio: >95dB
Damping Factor: >250
Separation: 60dB
Fuse: External 100A
Dimensions: 19" x 9.3" x 2.1" (48.3cm x 23.6cm x 5.3cm)
Typical output with 14.4V is 20% higher.
On Hold for now shipped firm.
Weeee!
Also have a Mint in box Kenwood eXcelon KDC-x592 135.00 shipped! No mounting bracket but has remote,trim ring and wire harness, USB ect ect.
3 4v pre amp outs, Bluetooth ready, Ipod compat.
I'll post photo's later to lazy to do it tonight. Sweet deck though slick look to it too.
Shinju
Shinju
Seattle
Shinju
