adrian1185
More Cowbell!!!
Is this amp any good? I tried the search function and did not find much on it. Is it under-rated or over-rated? Does anyone have experience with these amps? I'm scared to buy it because I've never heard of them.
Features:
* PMA800DA
* 1-CHANNEL CLASS D
* MONO BLOCK AMPLIFIER
* 800 Watts x 1 @ 4 Ohm Mono
* 1200 Watts x 1 @ 2 Ohm Mono
* 1640 Watts x 1 @ 1 Ohm Mono
* Dimensions (W x H x L) 9 1/8 x 2 1/2 x 15 3/4”
* Linkable with Second Identical Model
* Hour Meter
* Heavy Duty One-Piece Extruded Aluminum Heat Sink
* Beveled Clear Acrylic Protective Cover
* Tiffany-Style RCA Jacks
* Parallel Line-Out RCA Jacks
* Removable Aluminum Side Covers Conceal Control & Terminal Panels
* MOSFET High-Speed Switching Power Supply
* Milspec Double-Sided Glass Epoxy Circuit Board w/ Through-Hole Plating
* Heavy 4 oz. Pure Copper PC Traces at All Preamp & Amplification Stages
* Internally Mounted Fan-Cooled Power Supply
* Solid Brass Nickel-Plated Terminal Blocks (4-Gauge Power, 8-Gauge Speaker)
* 4-Way Protection Circuitry: Thermal, Short Circuit, Overload & DC Offset
* Variable Low-Pass Filter: 50Hz - 150Hz @ 24dB/Octave
* Variable Subsonic Filter: 15Hz - 40Hz @ 24dB/Octave
* Variable Bass Boost @ 45Hz: 0 - +18dB
* Variable Phase Shift: 0 - 180°
* THD:
* Signal-to-Noise Ratio: >100dB
* Frequency Response: 5Hz - 250Hz
* Input Impedance: 10kO
* Input Sensitivity: 300mV~8V
* Cooling Fan(s)
Features:
* PMA800DA
* 1-CHANNEL CLASS D
* Hour Meter
* THD:
* Cooling Fan(s)
