Sold Alphasonik hca 1000
jshak07
148.4 and climbing
Got this in a trade but looking to sale it as to Im gettin a 3000d.. Will get some pics of it up later tonight.. Asking $250 plus shipping.. Only trades I could use are batteries or if somebody wants to trade for a 3000d with cash on my end or maybe some components.. Will entertain all offers tho.. Seems to do a little under rated power but very close to it with good electrical! Comes with volt meter that can be ran like a bass knob.
2 Channel High Current Power Amplifier
RMS Power Rating: 3000 watts x 1 chan. at 1 Ohm Mono
RMS Power Rating: 1500 watts x 2 chan. at 1 Ohm Stereo
RMS Power Rating: 900 watts x 2 chan. at 2 Ohms Stereo
RMS Power Rating: 500 watts x 2 chan. at 4 Ohms Stereo
Hour Meter to log amplifier usage
Remote mount Bass Remote control included
Remote mount Digital Voltmeter included
ANL gold-plated Fuse Holder included
Heavy duty heat sink
Beveled clear acrylic protective cover
Tiffany-Style input and output RCA jacks
High speed switching power supply
Double-sided glass epoxy circuit board
S/N Ratio: >100dB
Frequency Response: 5Hz-50kHz
Variable low pass filter: 50Hz-250Hz
Variable high pass filter: 50Hz-250Hz
Variable subsonic filter: 15Hz-60Hz
Variable bass boost at 45Hz: 0~+18dB
Variable phase shift: 0~180 degrees
Input sensitivity: 200mV-8V
Input impedance: 10K ohms
4-Way protection circuitry: thermal, short circuit, overload, and DC offset
On board hook-up terminals
Dimensions: 26"L x 9"W x 2-5/8"H
Would give it an 8/10 cosmetically,, 10/10 functionality
Returned.. Pics will be up later tonight, I am at work right now
Got this in a trade but looking to sale it as to Im gettin a 3000d.. Had about 120 hrs on the hour meter.. Will get some pics of it up later tonight.. Asking $250 plus shipping..
Does it make 3000wrms @ 1ohm ? And that is in mono mode right...Cuz I saw the end
images
And it kinda looks like a 4ch amp, now I know its not but how would
you wire a sub into this thing in mono mode?? Just bridge it some
way??
And what size are the batt terminals thanks
Yea it does 3000 at 1 ohm mono
2 Channel High Current Power Amplifier RMS Power Rating: 3000 watts x 1 chan. at 1 Ohm Mono
I will put some pics up, if you bridge the 2 channels into 1 ohm it gives you 3000 mono.. You wire 1 ohm into each channel for 1500 stereo
I havent used it myself but from what Ihave read around on the internet it does close to rated power, the better the electrical, the more power.
In the pic below you can see it is missing one mounting tab, I have it, it is just not on there right now because when I got it, it wasnt on there and i havent got around to puttin it on.
It will take some 1/0 but you may have to trim it down. I might be able to dig up some 1/0 to 4 gauge adapters if needed tho.
jshak07
148.4 and climbing
jshak07
louisville
infamous_e46
