All 8's All New
infamous_e46
hArRy_DaNgLeRs
cadence cvl8-5004 svc 4 ohm 500wrms aka dd clones
rockford fosgate he2 dual 4ohm 8 inch
cadence new in original packaging
rockford's tested and put back in original boxes
235 shipped for cadence 8's depending where you're located
150 plus shipping for rockfords
cadences are louder and handle more power but the sq from the rockfords is quite noticable
Model CVL8-500-4
8” Single Voice Coil 4 Ohm Subwoofer
Specifications:
• 2” Voice Coil
• RMS Power: 500 Watts
• PEAK Power: 1000 Watts
• Frequency Response: 20Hz – 500Hz
• Magnet Weight: 7lbs
• Structure Weight: 9lbs
• Sound Pressure Level: 92dB @ 1w/1m
• Mounting Depth: 4.8”
Features:
• Super High Power 8” Subwoofer
• Double Magnet with Quad Spider Design
• Woven Carbon Fiber Inverted Cone
• Direct Connect 10 Gauge Power Wire
• 2” Four Layer Kapton BASV Voice Coil
Rockford Fosgate HE2
FIBERLock woofer with large roll treated foam surround
Dual voice coil design
CONsealer gasket hides mounting screws and stops bass-robbing air leaks
Frequency response 35-200 Hz
Power range 75-250 watts RMS (125 watts per voice coil)
Peak power 500 watts
Sensitivity 84 dB SPL
Top mount depth 4-1/2"
Sealed box volume 0.1-0.50 cubic feet
Ported box volume 0.1-0.75 cubic feet
Image Hosting at TurboImageHost.com
working with .65 per chamber sealed
---------- Post added at 12:58 AM ---------- Previous post was at 12:58 AM ----------
truck boxes //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Specifications
Recommended Sealed Box Volume: The sealed box volume range recommended by Rockford Fosgate is 0.1cu/ft to 0.5 cu/ft. Within this range, the ideal size recommended by Rockford Fosgate is 0.3 cu/ft, so this is the enclosure recommended by Crutchfield.
Recommended Ported Box Volume: The ported box volume range recommended by Rockford Fosgate is 0.1cu/ft to 0.75 cu/ft. Within this range, the ideal size recommended by Rockford Fosgate is 0.625 cu/ft, so this is the enclosure recommended by Crutchfield. One 2.5" diameter x 11.25" long port should be used with a 0.625 cu/ft enclosure. This tunes the box to 35 Hz.
Power Handling: The woofer has two 2-ohm voice coils, and each coil can handle up to 125 watts RMS (250 watts peak).
infamous_e46
hArRy_DaNgLeRs
infamous_e46
California
infamous_e46
