Old school Klipsch horn loaded a simple dome tweeter. Who knows, they probably do the same thing today. But a compression driver if you take it apart, has a voice coil much like a dome tweeter so you might as well just get a compression driver
from a good vendor and buy the appropriate horn lense that suites your needs
and low frequency response. EV, JBL, Radian, TAD, etc., high end brands.
My friend's ancient Klipsch system, he blew the tweeters and I just bought some
$20 dome tweeters and mechanically attached them to the horn lense as a quick
and cheap fix, it worked fine, he was happy as a hog.
Peerless makes a dome horn tweeter. They have two version of the tweeter,
the only different is the plastic attachment, one is regular, the other is a small
horn.
http://www.speakerbits.com/net/catalogs/images/thumbnails/PD026E.gif
Compression driver
http://www.loudspeakersplus.com/images/SND44-RD.jpg
Horn anything will have it's own unique sonic personality and you have to
audition horns to see if you like the sound. There is no other way to understand
it's behavior unless you sampled them. If you were to horn load an ordinary
dome tweeter with a small lense, frequency response will be peaky at some
frequency and SPL rises, sound quality drops. If you EQ the peak, then you
lose your SPL rise and you have a tweeter that isn't doing anything productive
vs. the standard one.
If you want lower frequency response, the horn lense gets bigger as the frequency drops.
You said you didn't want a loudspeaker with high SPL, but you want it to
operate down to 1khz - 1.2khz ? Question is ... why ? Have you identified this
as a must have design goal ? If so, you are crippling your tweeter choices and
only a few are candidates.
You will also mess with dispersion as horns are more directional. I like horns,
I have some huge EV compression drivers and HP640 horns that crank SPL
with clean sound a few blocks away, but I don't want them in an ordinary home,
theater - ok ...
That's why I collect those crazy pro planars. They satisfy alot of areas.
1. They have high SPL, not quite as high as a horn but it's much higher than any dome can produce.
2. They are flat down to 1.6khz, you can take the crossover lower if you really
wanted.
3. Waveguide option to boost the midband frequencies, boost sensitivity to 107dB. This is only good in concert application, home or cinema the waveguide is
not needed.
4. Robust driver - You can easily blow a dome or pure ribbon tweeter, but the
planars take a beating. Even the cheap $25 PT2 can handle some torture.
5. Audiophile SQ. These planar will sound as good as any high end dome tweeter
but not compress and distort like a dome will at higher SPL.
I can drive this tweeter at 1.2khz easy and get quality sound, but overal it
doesn't sound good as you are asking your tweeter to do midrange duty,
let your midrange driver do the midrange frequency. Realistically, 1.7khz
with a steep slope, 4th or 8th order is the lowest you want to drive any
tweeter in a normal 2 or 3 way loudspeaker design, any lower and you will
have bad sound with raunchy midband. If you don't need high SPL, then do look
at horns.
