AB hd 12's finally in
The box is most likely going to be the thing that vibrates the least in a trunk.
I disagree. With a box of that size there is and can be alot of box flex and vibration. I know Peas took a lot of time to make that box solid but it will still vibrate alot.
Although I'd rather not put an amp on the box anymore things like rubber feet can help dampen the vibration.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I totally understand it cant fit anywhere else(they are huge amps). I was just trying to warn you if one day you cut the amp on and hear pop. It gives no warning just goes up in smoke.This is the reason I run M3's now and not one big amp. Small amps are just more reliable in bad vibrating situations. Never know you may get lucky and never have it blow. Just trying to help you out.
thanks man, i just put some rubber shims under the feet to soften it up a lil bit. will see what happens. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif.
peas247
Hookers on the Point
peas247
buffalo, ny
peas247
