IDSkoT
Resonating Reticular
I recently bought a vintage record player. It has a tube amp running a single 4" speaker at .5 ohms. My mouth dropped when u measured it. Do tube amps normally nominal that low? Second, the tubes themselves have a black burnt part on the top of each one. Should they be replaced? (if possible.) after a few minutes of play, the tubes are too hot to touch. this unit was made in 49. It boasts 45 watts. But idk If that's including the turntable motor. But something tells me this is a replacement amp because of it's situation inside the box and there's a black sort of burn mark where the amp was. Pix can be posted if you want.
One tube says 35w4 then what looks like 5-04, and under that it says 188-20
The other says 50c5. And also 5448
I would look it up myself but the only Internet I have is my iPhone, and looking for information on it takes a huge chunk of patience.
Also, should I replace this speaker with one with more resistance? This amp gets really hot. Or is that normal for light bulb amps?
