Sold ((((((((((_________FS MTX Thunder 4300x_____________)))))))))))))
BloodyGuts335i
Team DC
1. Product:
MTX thunder 4300x
2. Specs:
-Patented PWM MOSFET Switching Power Supply (#5,598,325)
-Class A 100% Discrete Driver Circuit Topology
-High Powered Transfomers
-N-Channel V_FET Output Stage
-Doubles Power into 2 Ohms
-Bridgeable, Multi-Channel Circuit Design
-1% Tolerance Thru Hole Metal Film Resistors
-Real Time Computerized Protection Circuit
-Acoustically Seamless Turn-on/Turn-off (i.e. no noise)
-Built-in 18dB/Octave Defeatable Crossover Variable 50Hz to 200Hz, HP or LP Selectable
-Alternate Output with Complementary 18dB/Octave Defeatable Crossover Variable from 50Hz to 200Hz, Selectable (2300X ONLY)
-Front and Rear Summed Line Level Outputs (4300X ONLY)
-Continuous Adjustable and Defeatable Thunder EQ Bass Enhancement Circuitry, Centered at 40Hz
-Low Level Inputs
-External Bass Control Port for easy Bass Adjustment via Optional EBC Unit (2300X ONLY)
-Front and Rear Individually Adjustable Input Sensitivity (4300X ONLY)
-Left and Right Individually Adjustable Input Sensitivity (2300X ONLY)
-Gold Plated, Heavy Duty Terminal Block Type Connectors
-2" Maximum Height for Easy of Installation
-Patented Split Shield™ Bottom Plate Design (#5,521,792)
-Patented Nylon Insulated Iso-Feet™ (#5,521,792)
-Bold and Aggressive Heatsink Shape and Size
4300X Specs:
RMS Power measured at 12.5 Volts DC:
37.5 watts x 4 into a 4 Ohm load with less than 0.1% Thd+N
75 watts x 4 into a 2 Ohm load with less than 0.3% Thd+N
150 watts bridged x 2 into a 4 Ohm load with less than 0.3% Thd
3. Description/Condition:
mechanically 10/10
cosmetic condition- 7/10
the edges are scratched up!
99% efficient!!!
4. Price: :
$150 OBO shipped!!
5. Pictures:
Nice amp. According to THIS page, it puts out a lot more that it's rated at lol.
90 watts x 4 into a 4 Ohm load
165 watts x 4 into a 2 Ohm load
325 watts bridged x 2 into a 4 Ohm load
GLWS!
Nice amp. According to THIS page, it puts out a lot more that it's rated at lol.90 watts x 4 into a 4 Ohm load
GLWS!
yea.. It's a great small amp and it sounds amazing!!! I didnt want to boost up the specs and have ppl thinking I'm just talking out my ***...
Thanks for the update on the specs..
if you google this amp, you will see it has great reviews.. if someone needs/want more updated pics just ask.. Thanks for looking..
BloodyGuts335i
Team DC
BloodyGuts335i
Morris County NJ
BloodyGuts335i
