8" or 15"
usually 15's will play lower frequencies, and bass might sound a little deeper, but out of those options i would go with 6 assassin 8's, interesting little setup, will get read loud.
Well about the 15Q and 12Mag, I guess if you wont to pay the extra money for the mag.
From what I understand just cause they look similar, THEY ARE NOT the same drivers... I owe a Q and love it, havent heard a mag YET.
I think also it depends on how much you wanna do with the setup. if you want an easy instal go with the Q and if you want to get into and build a 6 8" box and all the wring then go with that. IMO 15" Q > 8" assassins
Cool. Im still in the air about it...
What about 15Q vs 12MAG?
I'd imagine it would be pretty close in output. But as Jim said, anyone who things the Q and the Mag are the same woofers has obviously not heard them both side by side.
In otherwords, the Mag is a much more dynamic woofer...that is from Jim's subjective listening results. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
In otherwords, the Mag is a much more dynamic woofer...that is from Jim's subjective listening results. Ive yet to hear a Q myself. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I done heard a little side on it also //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
The 15" Q will have about 26% more displacement potential than the 6 8s, would be easire to wire, and is just a better all around option i believe.
Edit: NVM //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
The 6 8s would be a much cooler setup. They may not dip as low, but my four could shake the steering column with a 25-32HZ songs just for comparison. They were almost as loud as my 15. I think the 6 would be louder. Feed each 3-400 watts and youll have a VERY loud setup...
6 Assasin 8's have enough displacement to dip as low as most 15's and would do the higher stuff (60-100Hz) better. 26% more displacement isnt a big deal for daily listening and if you are going ported, displacement is almost entirely moot anyway.
Im going with the 12" mag if i can get it, (special conditions). If i cannot its going to be the 15" q for me. Its one or the other and price in this situation doesnt matter... Base your judgment on if the subs cost the same which would you buy???
say $350 for the 12" mag and $350 for the 15"q if this was the case what sub would you buy?
nbudros
E-THUG
nbudros
DFW, TX
bigbangtheory
