JL TR350-cxi 25 +shipping
Continuous Power Handling: 25 Watts
Rec. Power Range (per channel): 10 - 40 Watts
System Efficiency: 83.0 dB @ 1W/1m
System Nominal Impedance: 4 ohms
System Frequency Response: 130 Hz - 22 KHz (± 3 dB)
JL Tr350-cxi
Pioneer TS-G1042R $10 +shipping
Watts MAX. Music Power 120 Watts
Watts Nominal Power Handling 25 Watts
Frequency Response 35 Hz to 30 kHz
Sensitivity (1W/1m) 87 dB
Ohm Rating 4
Mounting Depth 1-3/4" (43 mm)
Cut-out Dimensions 4-1/8" (106 mm)
Pioneer TS
CDT 6.5" grills $10+shipping
Lightning Audio 6.5" grills $5+shipping
Kenwood 6.5" grills $5+shipping
12"L7 grills sprayed black... probably need some sanding and paint $10+ shipping
California Profile 400sx $20+shipping
Peak Output Power (4 Ohms) 200W x 2
RMS Output Power (4 Ohms) 100W x 2
RMS Output Power (2 Ohms) 150W x 2
Bridged RMS Power (4 Ohms) 300W x 1
MOSFET Power Supply
Total Harmonic Distortion
Signal / Noise Ratio > 105dB
High Level Inputs
Variable Bass Boost @ 45 Hz 0~12 dB
Switchable Crossover LP/ Off/ HP
Variable Crossover Frequency 40~130 Hz
Power Terminal Size 6 Gauge
Speaker Terminal Size 6 Gauge
Fuse(s) 2 x 20 A
Dimensions (2 1/4"H x 9 3/4"W x __ L) 10 9/16"
cali profile site
JL Tr350-cxi
Ohm Rating 4
Pioneer TS
MOSFET Power Supply
High Level Inputs
Fuse(s) 2 x 20 A
cali profile site
