556L Bypass trouble 556L (2003 Saturn L200) Help!!
Hello all,
Ok Im dying here, somebody please help me. I've finished installing 564T Hornet Remote star/security system and I've installed the 556L bypass module but for the life of me, I can't get the **** thing to remote start. Engine turns, starts for 1 second. shuts off. Each failed attempt sends me back to the 10 minute long tamper mode. I've installed a relay for a (-) output switch on the keysense wire. I've checked every wire going to and from the module with a multi-meter and everything looks to be in order. I've done the programming routine for the bypass which has no problem learning the resistance according to the LED on it. I installed a manual switch on the yellow R-code resistance wire just to make sure it is the Passlock II system causing the problems. I start the engine with the key, flip the toggle to cut the resistance wire which puts the vehicle in fail enabled status (securty light and wrench light on, passlock disabled) shut the vehicle off, remove key , and try the remote start from there...which of course there is no problem starting the vehicle. But as soon as I reactivate passlock II, no start with remote start. I've done the learn routine countless times to no avail. What am I missing? Has anyone else had trouble with the Saturn L-series 2003 and up? Could it be my module?
sedition42yz
sedition42yz
Clarksville, TN
Shyne151
