Audio4ever 10+ year member Box Chevy Boi 2,114 1 Maryland Apr 10, 2011 #1 when using a o-scope which test tone is better 0,-3,or-5db 40hz tone?? i found a thread somewhere telling the pros/cons of each but i cant find it now Click to read more...
Kangaroux 5,000+ posts I put on 10,170 236 Maine Apr 10, 2011 #3 i used a -3dB 50Hz when I set my gains. Most music is around -3dB
OP Audio4ever 10+ year member Box Chevy Boi 2,114 1 Maryland Apr 10, 2011 Thread Starter #4 big diff 40 vs 50hz?
CHEMMINS 10+ year member CarAudio.com Veteran 4,277 115 Nevernever Land Apr 11, 2011 #5 Not really.....I 'd do it at whatever I plan on tuning to.
OP Audio4ever 10+ year member Box Chevy Boi 2,114 1 Maryland Apr 11, 2011 Thread Starter #6 box tuning??? if so it 36hz i believe
OP Audio4ever 10+ year member Box Chevy Boi 2,114 1 Maryland Apr 11, 2011 Thread Starter #7 liink to a -3db 40hz tone??
lowriderram_95 10+ year member VW Surgeon 1,712 6 Little Rock, AR Apr 11, 2011 #10 check out the decaf collection thread, I think he's got a tone in there that'd work for ya
Kangaroux 5,000+ posts I put on 10,170 236 Maine Apr 11, 2011 #11 i just made mine in audacity. hold on ill make one for you and pm 1
OP Audio4ever 10+ year member Box Chevy Boi 2,114 1 Maryland Apr 11, 2011 Thread Starter #12 i just made mine in audacity. hold on ill make one for you and pm Click to expand... ok thanx
wickedwitt 10+ year member Junior Member 3,091 37 Tahoka TX Apr 11, 2011 #13 Reason most use a 40hz is that is the boost signal on 99.9% of amps. That will be the most boosted tone your stuff ever sees. You set it to not clip there, it won't clip on any other note.
