46panel's 4 18" Fi BL's on 6000 watts
Thanks but yea I'm not competing and I really like the way it looks and it is loud enough for a daily driver. If I switch anything it will be to nightshades which work well in 4 cubes.
yeah i like the box design and i really like the port but i'm almost positive you would be happier with more room for them even if you aren't competing. you lose efficiency when the box is small and if you want to keep it small i say get two 3500ds and a few more batteries. or switch to 15s //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif even with the nightshades i would think you would get better results staying closer to 5 cubes per sub
Yea I hear ya, actually wanted to try 15's just already had the 18's.
nice videos man
Thanks
nice but its not moving much air. ive got a vid of my gf doing a better hair trick in the denali with all the windows closed in the back seat. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
No matter what I have ever did, I've never had good luck with a hair trick. Two 18's in 15 cubes, three 18's in 15 cubes and now 4 in 16 cubes, had a wall, had slot port/big aero ports.
Well try using different songs, play some songs that hit the low 30hz range. All the songs i see in your videos are in the mid 40's. depending on where youre peak is at you might do a better hair trick with lower frequencies
Yea I think I am doing a better hairtrick with all the windows sealed being inside also.
Just headed back down to Saginaw...probably will make a trip up north one more time before I'm home for the summer. Probably around the 1st of april, if not then I'll be back around the end of april.
46panel
46panel
Michigan
46panel
