45 degree corners...
Not really unless you know someone what knows the width you want, or if you just want to set it flush in the corner, you might as well get a square strip and call it a day.
Lol you lazy bastage. Over in the weather stripping section of home depot they have thes plastic corner braces. They would need to be covered with resin. They are kind of weak for inside the box.
You could just cut about an inch or inch and a half of MDF and sand the corners to fit in the corner...
or you can go to home depot, but the roudn cardboard concrete tubes, cut sections off. place inside box, resin, and you have a perfectly rounded corner....tis what i do.
PVC, and or any round/cylindrical object thats long enough to span the height and width of the box will work...
danteBirosel
danteBirosel
San Diego, CA
danteBirosel
