4- tantric shd 15's dual .5
nutnbutcustm
IM OLD
1,404
Spring,TX.
Item(s) for Sale: 4-15" TANTRIC SHD'S DUAL .5
Item(s) Description/Condition: COSMETICALLY 9.5/10 MECHANICALLY 10/10 VOICECOILS ARE PERFECT AND HONEY GOLD, QUAD TENSIL LEADS THESE WERE DESIGNED FOR MUSIC NOT FOR BURPS BUT WILL STILL PUT OUT SOME NUMBERS AND GET LOUD ON MUSIC AND VERY CLEAN.
Price: 550.00 EACH
Shipping and Miscellaneous Item Information: ON YOU, THEY WILL BE BOXED UP EXTREMELY WELL AND THEY ARE NOT SMALL SO IT WONT BE SUPER CHEAP.
THE TANTRIC ON THE RIGHT (BLACK ONE) COMPARED TO A B2 AUDIO XC 15
forigve my newbness, but my wiring options with these would be .25, .5, and 1 correct?
what subs are you replacing these with? and when will they be in? ill be down sometime before mid june i hope everythings together by then, if not id be down to lend a hand:cool:
forigve my newbness, but my wiring options with these would be .25, .5, and 1 correct?With all 4 of them you could run 1.4 or .35 because how the coils read they are dual .5 but read .7
what subs are you replacing these with? And when will they be in? Ill be down sometime before mid june i hope everythings together by then, if not id be down to lend a hand:cool:
im staying with tantric just going to try something a little different......
760
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
782
880
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
nutnbutcustm
IM OLD
nutnbutcustm
Spring,TX.
nutnbutcustm
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
