4 ohms vs. 8 ohms??
07ramjam
I dont know if this has been asked or not so Ill ask it anyway.
If I have an amp thats 500@4 ohms 1200@2 ohms and 1600@1ohm how many watts would it be at 8 ohms?Right now I have a Dual 4 ohm sub thats currently hooked up at 8 ohms.I just trying to figure out how much power I might be sending it?Is it half of the 4 ohm spec??
id wire it down to 2ohms instead...the difference between 2 and 8 ohms is just the resistance the amp sees.. ohms law states V=IR, so if you lower the resistance current will go up because voltage is constant..
07ramjam
07ramjam
Temecula Ca.
AllDayMJ
