4 fi bl 18s
No need to double all the way around. 3/4" all the way, double the top plate and build braces for it.
OP - You're going to need roughly 2x that space for four ported 18's, just to let you know. After box and sub displacement...yeah
So re-think it. Four 15's might fit you a bit more reasonably.
I'd tripple it all the way around to eliminate the need for bracing. Less obstacles inside of the box, simplifies the process. Works out all around. I would go with birch rather than MDF as well just to save on weight...
x2 on birch. But price=//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Dude, I had a box with 2 Solo X 18s that was made out of 2" trupan all the way around.
My van had a wall with with 4 " all the way around.
That's great. +1 for you. I didnt say it wouldnt work, I simply said there was no need for all of that.
Yes, I'd rather have a box that was doubled up all the way around, but once again if you double the top plate and brace it correctly you dont need that.
All I said.
It should be a good 20 cubes for 4 18's...if not more
20 cubes is not nearly enough for the bl's IMO.
i can tell you there was a very drastic and very positive response when i removed a 18" bl from a 5.5 cube box, into a 7.5 cube box.
IMHO, you need to shoot for at least 7 cubes per 18, IE 28 cubes net volume
All I said.
You ever seen a box blow apart?
I agree, I think the OP has watched too many of Meades vids and shouldn't choke the 18's off as he does. I think 4 15's would have better results due to space constraints.
Yea I would want to see around 7 cubes per 18, I was kind of setting a bare-minimum for what it should be
OP may want to do a little research before embarking on such a large system.
3/4 MDF is a must, and needs to be braced and or doubled. 20 cubic feet would be the minimum I would go for 4-18's, anything less and you might as well just use 2 and get the same results.
Ok so a 4 foot wide by 3.5 foot by 2 feet tall should give me enough space correct?
I will also be doing as grubbs suggested and use 3/4 all the way around and just properly brace it and double it up in some areas. Also I have still not decided on highs / mids, what would you guys reccommend?
Thanks!
tholley
tholley
u.s.
tholley
