As others have said, you truly are clueless. I won't bother explaining anything since it's clear that it's either over your head or you just haven't bothered to read it. Just as a final note to you in case hearing it one more time will help you: due to the differences in frequency and phase, your mids and tweeters won't give you a higher score if they by themselves are not making 130db and your sub is. If your mids and tweets together are somehow making 135db with your sub making 130, then you'll score a 135. That is then the peak across the entire spectrum and the meter will pick that as the high score. I recommend that instead of using mindless insults that you bother to pick up a book on acoustics or basic fluids because you really don't understand what you're saying. I know what you're thinking: a subwoofer sweeps a large amount of air + 16mids sweeping a large amount of air = a LARGE amount of air. Unfortunately, it doesn't work like that because the "air" is soundwaves of different frequencies and as such, they don't add together except for at the furthest harmonics which are negligible anyway. In all seriousness, good luck with your project.
