Sold 3 Autotek MM4000.1's for sale...
F150Matt
Time to get some more power for next season. These amps are very strong on 12-14 volts. I've been using them since the beginning of the summer. They were used to set the USACi Pro Stock 5001+ B&K World Record and to place 2nd at World Finals this year. Information can be found on them at http://www.maxxsonics.com/autotek/mm_amps_SuperD.html
They are 4000 watts at 2ohm mono. I have 3 available. I'm asking 750+shipping each but will make a deal if you buy more than one. If you need batteries to supply these amps check my other post. Thanks.
They are 4000 watts at 2ohm mono. I have 3 available. I'm asking 850+shipping each but will make a deal if you buy more than one. If you need batteries to supply these amps check my other post. Thanks.
how much do these go for new?
do you still have the autoteck MM4000.1Ds and do they put out rated power
bridged @ 2 ohms. I may be intersested in 2 at some point in the future.
The amps are 2 ohm mono stable. Their sweet spot is a 3 ohm reactive load. Depending on the strength of the motors on your woofers and the enclosure you use, the optimum nominal impedance that will yield around 3 ohm reactive is usually between .7-1.2ohm. This would be for burps only. For daily use they aren't recommended any less than 2 ohm reactive although I'd guess 1.4-1.5 would probably be safe. We've played them a little lower than that on a daily basis, but our idea of daily beating and others can sometimes be different. And yes I still have them.
David,
If you'd like 4 I can inquire to see if the guy I borrowed one from so that I would have 4 for finals would like to sell his as well. PM me if you're interested. I can work with the price a little if you buy all of them.
Im Shawn MF'in Fleming and I approve this for sale ad, and its seller!
This advertisement has been paid for by matt sibley, and the shawn is the greatest only for profit fund. We now take you back to your normally scheduled programming.
Here is a pic of us using the amps to test some different boxes in one of my teammates cars. We just set them up on the floor to my NSB's so we could try a bunch of different boxes before we put the amps in the car.
Below are some pictures of the amps installed in my car...
These are the amps that were mounted underneath the shelf that my box rests on in the CRX, box was photoshopped out..sorry //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
These are the two amps stacked together in the back of the car...box was photoshopped out again.
These are a couple of the boxes they ship in.
Let me know if you need anything else.
F150Matt
F150Matt
Houston, TX
F150Matt
