Since when this form became bias against people with limited knowlege and since when asking people's opinion was wrong?Quit asking n00bx questions...
They are ghey.
nG
no back seat isnt comming out i would be going behind the back seatif you have the room, money, and since you have another 2400d on the set of 15s, i suppose id go with that.. i dont know though it might not necessarily be louder in your car than the two 18s..
either setup is gonna be loud. are you competing? where are these going, back seat out? cut through?
ok you do realize that each 15" is gonna require at the MINIMUM of about 4 ft3 each, and 18's probably at least 6 each. there is no way you are gonna fit that in unless you do a blow through, and then your bed would be totally taken.no back seat isnt comming out i would be going behind the back seat
it's a 4 dr blazer not a pick upok you do realize that each 15" is gonna require at the MINIMUM of about 4 ft3 each, and 18's probably at least 6 each. there is no way you are gonna fit that in unless you do a blow through, and then your bed would be totally taken.
