Sold 2x12" SI BM's and AudioQue 1200D
Info From Site
Big output, tiny mounting depth, tiny enclosures; that’s what the BM series is all about. Using the same technology we use in our Mag series, we put the motor of the BM’s inside the basket to shrink the mounting depth to 3.5 inches!
Utilizing an XBL^2™ motor to give you long, linear travel, along with our top choice soft parts that include a honeycomb composite flat diaphragm and inverted foam surround, the new BM series will give you unprecedented performance from a shallow mount package. Not only can you can mount them behind or underneath almost anything, but you can also use virtually any speaker grille (thanks in part to the inverted surround). If you thought you only had the room for an 8” or 10” sub, you now have the room for a 12” sub with the new BM subwoofer.
Key features:
» FEA optimized XBL^2™ motor
» Dual 4 Ohm voice coil configuration
» 500 watt power handling
» 2.5” copper voice coil wound on an aluminum former
» Inverted foam surround
» Honeycomb composite cone
» Shallow mount design (3.5”)
» Tiny enclosure requirements
» Lightweight design
Recommended enclosures:
» 0.5 cubic feet sealed
» 1.3 cubic feet ported, tuned to 34 Hz.
» Recommended power range: 200-500 watts RMS.
It says 200-500 RMS, but they will take 600-700 no problem
ChrisR19
ChrisR19
New Port Richey, FL
ChrisR19
