24hour drver burn-in
should you? seems like a personal type thing to me. Do you want it loosened up before you get it? or do you want to do it yourself?
pretty useless thread.
what I meant was is there A down side //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
It will loosen the suspension for you, meaning you don't have to play the driver at high excursions yourself at first to get to that point.
So again, do it if you would like the driver already loose and ready to roll.
Since this is a opinion type thing, I PERSONALLY like to do it myself...its fun to watch //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
U can get A 24hour driver burn in for the mach 5 audio 12" sub for free should I get it. I plan on buying one next week:)
Hi Jeremiah,
The burn in process ensures you don't get a DOA or faulty unit. 24 Hours is not much time on a sub, but it does help shorten the length of time before the driver reaches its "happy point".
You get a full warranty with the unit, so "time spent" on a driver is a non-issue.
As others mentioned, it is still a personal preference to many.
Best regards,
Mark
Burn in isn't a necessity, but as was already stated, it isn't a bad idea either. It helps reveal any DOA flaws before you get the woofer. I got an ID Max once that starting scraping horribly about 30 seconds after playing. Those kinda of QC issues can be avoided by the end user altogether by the manufacturer or vendor doing a burn in test. It's not like the test shortens the longevity of your woofer or anything...
jeremiah
edit me but not ****? ok?
jeremiah
Canton Texas
jeremiah
