Sold 21" Autotek, Elevation DX1500.1, Eclipse 8053, Livewire, EHQS 12's, Sherwood Amp...
RAM_Designs
SketchUp Master
Trying to lessen my for sale threads, so here it goes...
1) Autotek XS-2111 21" Subwoofer --$1500 shipped--
One bad mofo here...brand new, with some scuffs on the surround, but nothing damaging...purely cosmetic.
t/s parameters
Fs Hz 30.80
Re Ohms 1.00
Qms 7.03
Qes 0.34
Qts 0.32
Cms 0.06
Mms/gr. 468.30
Sens. dB (1w / 1 m) 92.70
Vas Cu.ft. 4.93
Le mH 1.60
Xmax mm 13.00
2) Elevation Audio DX1500.1 --$300 shipped--
Board made by Zenon, same board as the saz-1500. I got this from nikosbuddy on here, but have upgraded to a Solid F2500D instead. It looks great with only VERY minor cosmetic blemishes...
1500 watts at 1ohm, but that's a 12.6V
stable at 1/2 also
3) Eclipse 8053 HU --$220 shipped--Very light scratches on the face, and no major wear of any buttons. Dead head, as many of you know, with awesome crossover capabilites, and indepent speaker TA and level control.
4) NIB Pair of Livewire 12" Subwoofer --$160 shipped--
I tested one out in a 2ft^3 box tuned to 40hz, and it gets pretty darn loud. Lowend sucks in that box, but I assume a lower tuning of 35hz or so can cure that. The other sub has never even been powered up.
- 12" (314mm) Die cast aluminum frame
- RMS power: 300-500watts
- Impedance: dual 4 ohms
- S.P.L: 92dB/w/m
- Fs: 24Hz
- Voice coil: dia 65mm TSV (4 layers)
- Magnet: 6- column star magnet 100oz
5) NIB Pair of eD EHQS Subwoofers --$70 shipped--
Qts : .375
Qes : 0.49
Qms : 1.506
Fs : 25 Hz
Re : 3.6ohm
Vas : 157 L
MMS : 90g
BL : 7.2 Tm
SPL : 89.1 dB
SD : 510 M^2
Xmax : 9.1 MM
6) Old School Sherwood 4 Channel --$40 shipped--
Good little 4 channel that does 4x25 at 4ohms...very small(9x5x2). In pretty good shape for it's age...
up for a guy that took some trash talk in his last threadglad to see u finally got em
GL with your sale that things massive
Haha, thanks. Dman's a great guy and owns a good shop that does great work and sells some high quality equipment...he was just looking out for himself since he's been screwed by someone reselling his amps on ebay, before the guy even had them...that's all.
Thanks, Ryan
i cant go to that link.. im on my work computor and they onley allow me to view what is on this sight.. sorry to be a bother..
no problem...these tests are done in a chevy aveo, btw...with the stock alt.
1 amp, single 1000ca everstart maxx, factory alt
4 ohm nominal = 518 watts @ 88% efficiency (voltage fell from 14.3v, to 14.0v)
2 ohm nominal = 948 watts @ 85% efficiency (voltage fell from 14.3v, to 13.6v)
1 ohm nominal = 1510 watts @ 78% efficiency (voltage fell from 14.3v, to 12.4v)
.5 ohm nominal = 1615 watts @ 72% efficiency (voltage fell from 14.3v, to 11.8v)
.35 ohm nominal = 1748 watts @ 67% efficiency (voltage fell from 14.3v, to 11.4v)
1 amp, single 1000ca everstart maxx, 1 Eagle Picher 12a5000, factory alt
4 ohm nominal = 520 watts @ 88% efficiency (voltage fell from 14.3v, to 14.1v)
2 ohm nominal = 960 watts @ 84% efficiency (voltage fell from 14.3v, to 13.7v)
1 ohm nominal = 1635 watts @ 75% efficiency (voltage fell from 14.3v, to 12.8v)
.5 ohm nominal = 1890 watts @ 71% efficiency (voltage fell from 14.3v, to 12.8v)
.35 ohm nominal = 2245 watts @ 65% efficiency (voltage fell from 14.3v, to 12.8v)
woah woah..
just because it uses the same "board" doesn't mean it's the same amp.
same "board" means SAME BOARD, not same components..
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
those specs are NOT accurate for this amp.
woah woah..
Obviously it's not EXACTLY the same amp, but for both of them to have the same board and same power ratings, and for both to be stable at 1/2ohm, the numbers can't be off by much, 5-10% at most?
Not to mention the DX1500.1 is rated for 1500 watts at 1ohm at 12.6V...
RAM_Designs
SketchUp Master
RAM_Designs
Rockwall, TX
RAM_Designs
