2012 F-350 CC LB 4x4 DRW Build Help
wanderer1
I would like some opinions on my front doors. I will be using CDT ES-06+ and a pair of CDT ES-4. I could Glass the drivers in the stockish location, I could put the ES6top in the stockish location, then seal the pocket area and mount the ES4s. Or I could seal the top pocket area into 2 separate compartments and mount the drivers i9n that area. Would the bodies be blocking the drivers to much? I'm using Zapco DC series amps with DSP to help and the sail panels will have CDT ES-010WD tweeters mounted there. Here are some location pics.
I'd cut away the part of the upper door pocket and form a large pod there. And I'd keep it from protruding out farther than the armrest. Basically utilized the space between the armrest and door pocket.
I had a chevy, the Ford served purpose better. I don't get into all that nonsense. Be hind the panel is a 5x7 and the rest is sealed up pretty good. Yeah a little glass don't hurt.
That's part of the question I asked, my concern was sound dispersion being blocked by the body. maybe the 4s towards the back in the pocket and ES-06+ in stock location?
wanderer1
wanderer1
Laughlin
wanderer1
