2 zx2500s, but one's hotter
  • Thread starter Ali1
  • Replies 0
  • Views 440
Ali1
e6300 FTW
Two zx2500s are placed inside the vehicle.... played some music for a while and found out that one of the amps gets hotter than the other. the amp thats getting hotter has been used for less than 2 months, while the other amp(less hotter) has been used well over a year by another user. Both amps are placed in the same position, so niether is benefitting from extra cooling. Each are seeing a ~2.8ohm load to each BTL. Amp never went into protect and its not hot to the point where i can't touch the amp,
shouldn't both amps be operating at the same ohmloads & same voltages, therefore both amps should be close to the same temperature? Should i be worried or is this normal when operating two amps?
Any help would be much appreciated........
Ali1
e6300 FTW
Ali1
U.S.
Ali1
