2 zapco competion c2k-4.0x amps
crxsir121
I have TWO Zapco Competition C2K-4.0X 4channel amps for sale. These retail for over $1700 each. I'm selling the pair for $1200 or $650 each FIRM!!! Will include original boxes. I will also include two balanced line transmitters and two symblink cables per amp. These cables are sold separately but will include them. In mint condition. NO TRADES!!!WILL HALF SHIPPING COSTS... Very high end amps and not swapmeet brand junk. My loss your gain...
View attachment 26533864View attachment 26533865View attachment 26533866View attachment 26533867View attachment 26533868
Stereo, 4 ohms: 4x100 Watts
Stereo, 2 ohms: 4x150 Watts
Bridged, 4 ohms: 2x300 Watts
T.H.D. + Noise:
Frequency Response: 20Hz - 20kHz; +0 dB/-0.23 dB
S/N Ratio: >100dB
Transient Distortion:
Slew Rate: >40V/uS
Damping Factor: >1000
Input Sensitivity: 1-4 Volts or 4-16 Volts
Dimensions: 19.5"L x 8.75"W x 2.375"H
-Chassis design allows infinite customization
options by replacing slide-in trim panels to personalize any installation
-SymbiLink™ Balanced Technology provides up to 16 volts of balanced input for the cleanest, quietest signal possible
-Pre-clip and output clip indicators to maximize performance settings
-Symmetrical, discrete power amplifier circuitry
-Fuse, short circuit, high temperature, DC offset, and over voltage protection
-Dual color LED for power and protection indications
- 25-amp High Current Bi-Polar output devices
- 50-amp MOSFET switching devices
-Optically isolated power supply
-Gate Drive Boost maximizes power supply efficiency and improves overall performance
-Very high damping for excellent speaker control
-Surface Mount Technology w/1% resistors, precision capacitors, and massive ground planes
-Four layer PC board with heavy 2 oz copper
-Dual variable electronic crossovers
-Pass-through output
-Sub-sonic filter for speaker protection
-Switch for use as stereo, single L ch. or R ch. bridge
-L+R sum mono switch for use as a bass amp
- Dual cooling fans allow any mounting position
Zapco C2k4.0X Zapco C2k 4.0X Competition 4 Ch 600 Watt Amplifier
crxsir121
crxsir121
San Diego, Ca.
Cpyro
