Screename is the SAME as on CACO
1. Product:
SPL SPLW-10 10" Subs
2. Specs:
Common Features
Cloth laminated paper cone with MD6 coating
Dual 1 ohm voice coil
Die cast aluminum basket
Aluminum/chrome dust cap for extra rigidity under extreme conditions
Black wrinkle finish with Diamond cut
Chrome finish front & back plate
Large roll treated foam surround
One piece, 360º rubber gasket
Dual conex spider Woven tinsel lead through spider
Chrome binding post terminals
SPLW-10
2200 watts power handling
1000 watts RMS
270 oz. magnet
3 BASV/Kapton hybrid 18 AWG voice coil
FS 32(Hz)
Vas 0.5 cu.ft.
Qes: 0.359 Qms: 3.53 Qts: 0.23
Xmax: 0.4
SPL 89 dB
Sealed box: N/A
Ported box: 1.65 cu. ft.
Tuning: 45 Hz
Port size: 3 (dia) x 9.25 (length)
# of ports: 2
3. Description/Condition:
Both New, Never Seen Power, Both Have Manuals, One DOESN'T Have The Original Box.
4. Price: :
$100 + shipping EACH.
THESE ARE THE ONES WITH THE ALUMINUM CENTER CAP NOT THE BLUE LETTER CENTERS.
1. Product:
(2)Selenium 10wp3's
2. Specs:
An outstanding 10" woofer for midrange sound reinforcement and stage gear. In PA applications, use two 10PW3s to complement and a 15" or 18" low frequency driver and a high frequency driver for a single enclosure for use in smaller clubs and mobile applications. Specifications: * Power handling: 150 watts RMS/210 watts max * Voice coil diameter: 1-3/4" * Voice coil inductance: .45mH * Nominal impedance: 8 ohms * DC resistance: 6.1 ohms * Frequency response: 60-6,000 Hz * Magnet weight: 44 oz. * Fs: 73 Hz * SPL: 98 dB 1W/1m * Vas: 1.02 cu. ft. * Qms: 6.32 * Qes: .73 * Qts: .66 * Xmax: 1.25mm * Net weight: 7-1/4 lbs. * Dimensions: Overall Diameter: 10", Cutout Diameter: 9", Mounting Depth: 4-1/2", Magnet Diameter: 5-7/8", Magnet Height: 1-3/8".
Used, Works 10/10, Looks 8/10 (magnet scratches & lil tape residue on one)
4. Price: :
$75 Shipped For BOTH
1. Product:
2. Specs:
Common Features
SPLW-10
1000 watts RMS
270 oz. magnet
FS 32(Hz)
Vas 0.5 cu.ft.
Xmax: 0.4
SPL 89 dB
Sealed box: N/A
Tuning: 45 Hz
# of ports: 2
4. Price: :
1. Product:
(2)Selenium 10wp3's
2. Specs:
4. Price: :
