2 sa 8" v2 talked to jacob " well the lady asked him a few ?'s for me "
Jason Eden
hi a few ? I want to run 2 8" off my orion 250 hcca about 1000 watts rms 1 ohm was thinking facing rear window of my 88 mazda
top 12"
cab plus /--\ facing the front of truck
bottom 20"
13" wide and 18" tall I believe thats about 1.4 with the divider board but with the sub displacement it will go lower like 1.2 i think.
1. can I run the front one inverted " magnate outside the box " whats the difference " i thought it might look cool "
2. should there be a divider between subs or run them together
3. how and where do i put a port " if i run together or in seperate boxes ?
thanks Jason
you can run inverted but do both ,divider doesn't matter ,usually deeper with out .port can be wherever you want ,drivers side is usually louder
I cant do both I think back one will not fit. I thought I could just make the rear box a bit bigger to make up for sub displacement. If they are divided it doesnt matter if one is inverted and one is not, right. also I see people saying like 22" long ports and crazy high numbers like that. what size and length port would work with the boxes I want to build? thanks
You're either gonna need to do a lot of reading or find someone to design the box for you. These small boxes are incredibly hard to get right, both in tuning and in volume after displacements.
Jason Eden
Jason Eden
apple valley ca.
UnderFire
