For sale are 2 Rockford Fosgate Power Series amplifiers (T1000-1BDCP and T400-4). These are my personal babies and were gently used in excellent condition and come with the instructions for the T1000-1BDCPand both the birthsheets. The bass knob for the T1000-1BDCP will also be included. Both of these amplifiers work perfectly and are in excellent condition. These amplifiers are very very well taken care of. Asking $430 shipped for both. I will not split up. No trades.
The specs for the T1000-1BDCP are:
Compact Class DB Monoblock Car Amplifier
RMS Power Rating:
4 ohms: 700 watts x 1 chan.
2 ohms: 1000 watts x 1 chan.
1 ohm: 1000 watts x 1 chan.
MEHSA MOSFET power supply
Utilizes TO-247 MOSFETs instead of TO-220 MOSFETs which have 60% more metal tab area for more power capacity, lower impedance and improved heat dissipation
Remote bass level input: Rockford Fosgate Punch required and sold separately
Power(blue), thermal(red), protect(yellow) LED indicators
Bass Boost (0-18 dB bass boost at 45 Hz)
Discrete Surface Mount (DSM) components decrease cross talk and operating temperatures by creating circuitry with a smaller footprint
Cast aluminum heatsink utilizes convection cooling techniques to evenly distribute heat around the entire amplifier
Differential RCA level inputs
RCA Passthrough
Audiophile grade speaker screw terminals
Variable low-pass filter (35-250 Hz, 24 dB/octave)
Butterworth Infrasonic Filter (24 dB at 28 Hz)
CEA-2006 compliant amplifier
Frequency response: 20-250,000 Hz
Dimensions: 13-5/8"L x 8-1/8"W x 2-1/8"H
The specs for the T400-4 are:
4-channel car amplifier
60 watts RMS x 4 at 4 ohms (100 watts RMS x 4 at 2 ohms)
200 watts RMS x 2 bridged output at 4 ohms (2-ohm stable in bridged mode)
CEA-2006 compliant
Dynamic Thermal Management cooling system
Differential Input circuitry eliminates hum
variable high- and low-pass filters (50-500 Hz, 24 dB/octave)
variable bass/treble boost (0-18 dB at 45 Hz, 0-12 dB at 12k Hz)
optional remote bass/treble boost (available soon)
Class-AB amplifier design
MOSFET power and output stages
preamp outputs
4-gauge power and ground leads and a 100-amp fuse recommended
13-5/8"W x 2-1/4"H x 9-5/8"D
The birthsheet specs for the T400-4 are 79 x 4 @ 4 ohms, 132 x 4 @ 2 ohms 264 x 2 @ 4 ohms. The birthsheet specs for the T1000-1BD are 800 x 1 @ 4 ohms, 1364 x 1 @ 2 ohms and 1421 watts x 1 @ 1 ohm.
I do not ship outside the United States.
RMS Power Rating:
RCA Passthrough
CEA-2006 compliant
preamp outputs
