2 Orion hcca d2400 and 2 eclipse sw9122 ti
smiley2186
2 orion hcca d2400 2 eclipse sw9122 ti
this diagram i found only show it wire to 1 sub, how can i wire it to 2 sub
im new to this, and new to working with orion, any help i get i appeciate.
Okay I bought 2 orion hcca d2400 mono and 2 eclipse sw9122 ti, I want to run 1 amp with 1 sub, how would I wire this up?
Pictures diagram would help a lot.
Spec on the amp orion hcca d2400 x 2
425 watt at 4ohm
800 watt at 2ohm
1200 watt at 1 ohm
fuse 40x3
Eclipse sw9122 ti x 3 but only using 2
750 rms and 1500 peak
I heard that the orion d2400 u can bridged together how? How do I wire up the rca wires it has input and output, master and slave button. My sub are wire up at 2 ohm each with 1 fiberglass box for each sub,”seperate” how do I wire it up to the the orions amp, orion tutorial said something about wiring the negative speakers wire together and the positive together, so how can I wire the amp to the sub.
all wires will be 1/0g wires
i also have two battery, alpine deck 9856 and alpine eq g180 11 band, and a alpine v12 4 channel amp.
Thanks two everyone that helped I really appreciated.
smiley2186
smiley2186
San Diego, CA
smiley2186
