Sold 2 HO Alts
loudwhat?
The Sundown Audio King
i have 2 HO alts that came off of a 1990 ford bronco ll with a 2.9 V6 what it will all fit i don't know you need to figure that out not responsible for not fitting your application if its different than what i stated the smaller one is the factory location 200 AMP it has a dummy regulator for a external regulator it comes with a "OEM" regulator and a smaller pulley for higher idle output
the second is a GM case alt that also came off the AC location on the same vehicle what all it will fit is up to you to find out it is a 250 AMP Alt it also has a dummy regulator and it comes with a "OEM" regulator and smaller pulley
Both alts are excessive amperage and are in great working order.
for the 200amp alt i am asking 300 OBO
for the 250amp alt i am asking 350 OBO
prices are shipped in the lower 48 states if you live elsewhere pm me your code and ill price it for you thanks
thanks to mechman i know what all they should fit :posted by MECHMAN View Post
Just FYI-The 6 and 12 O'clock mounting ear unit is a large case 3G ford alt, and will fit almost any 1965 - 1995 Ford that has the standard 6 and 12 O'clock mounting ears.
The smaller units is an offset mounting small case 3G that pretty much only fits 6 cylinder and some four cylinder Ford applicatons through the 80's and 90's
loudwhat?
loudwhat?
statesville, nc
loudwhat?
