Sold 2 channel amps, mids, highs, passives, dual 6.5 box, accessories
fast306stang
Well, like many of you, I have changed my mind about my build and I have bought some of the other items I need. So everything I don't need is listed here for sale. I might be open to trades, we will just have to see if I can use what you offer. I have everything I need for my current planned setup.
Link for pics is at the bottom.
ED NINe.2: $135 shipped
Mint condition except for a couple of rub marks on one endplate.
Box and manual, all mounting hardware included
2 x 100 @ 4Ohm THD
2 x 150 @ 2Ohm THD
1 x 400 @ 4Ohm THD
signal to noise ratio >-90dBa
damping factor >250
frequency response 10Hz-30KHz
stereo separation >-60dBa
input sensitivity 200mV-5V
input impedance 10K ohm
high pass 40-240Hz 12dB
low pass 40-240Hz 12dB
dynamic bass boost 12dB
bass eq frequency 45Hz
phase shift N/A
remote control capability N/A
US Acoustics USB 2080: $75 shipped
9.9 condition, box included, no manual or *feet*
•80 watts RMS x 2 at 4 ohms
•140 watts RMS x 2 at 2 ohms
•280 watts RMS x 1 bridged output at 4 ohms
•4-ohm stable in bridged mode
•stereo or bridged mono output
•Tri-way capable (Tri-Way crossover required)
•requires 10-gauge power and ground leads
•variable high-pass (65-4500 Hz, 12 dB/octave) and low-pass (40-460 Hz, 24 dB/octave) crossovers
•anti-thump circuit
•speaker-level inputs
•preamp outputs
•thermal, short-circuit, and power/ground reversal protection
•10-3/16"W x 2-5/8"H x 9-5/8"D
Features
Power Supply and Output Devices: High-current MOSFET devices are used in the power supply and output stages of this amplifier.
Anti-thump Circuitry: There is a time delay turn-on with opto-coupled muting circuits for quiet, thump-free operation.
High-speed, Audio-grade Components: High-speed, audio-grade components are used in all low-level stages to help ensure signal integrity.
Internal Crossover: The internal crossover can be set for flat (full-range), high-pass or low-pass operation. The low-pass frequency is variable from 40-460Hz with a 24dB/octave slope. The high-pass frequency is variable from 65-4500Hz with a 12dB/octave slope.
True Line Output: The gold-plated RCA outputs on this amplifier are able to send flat (full-range), low-pass or high-pass signals to a second amplifier. If the internal crossover is set to flat (full-range), the line outputs will pass a full-range signal. When the built-in crossover is set for high-pass operation, the line outputs provide a low-pass signal. When the built-in crossover is set for low-pass operation, the line outputs provide a high-pass signal.
Protection Circuitry: Reverse polarity, thermal and short circuit protection circuits are used to help protect the amplifier from damage and ensure reliable operation.
LED Condition Indicators: A green power LED and a red protection LED are used to indicate the amp's operating status.
Profile Baja HA600: $60 shipped
9.5/10 condition, box, manual, mounting hardware included.
Box has been around the world a few times...
Don't let the brand name fool you, this amp actually sounds very nice
2x100wrms@4ohms
2x150wrms@2ohms
1x300wrms bridged@4ohms
THD@rms power
20Hz-30Khz
signal to noise >100dB
stereo separation 83dB
pre amp output
200mV-7V input
12dB/Octave x-over slope
LP x-over 50Hz-250Hz0Hz-1.2kHz
HP x-over 80Hz-1.2kHz
Bass Boost @45Hz 0-12dB
damping factor 280
40A fuse
2 1/4 x 9 11/16 x 11 13/16
Alpine 6.5 mids (from an SPR-17S set) SOLD!!!!
I bought the set new/authorized and sold the tweeters/crossovers.
I used these in testing and have a build I was going to use them in, but things change, lol.
Grills and all mounting hardware included. They *might* have 30 minutes of play time on them, if that.
Diamond Audio 1" aluminum tweeters $30 shipped
I bought these to pair up with the Alpines, never had power to them.
No box, and I think I only have flush mount hardware--I will check
Blaupunkt VC-100 crossovers $30 shipped
I love the look of these crossovers...I was going to use them with the Diamond tweeters and the Alpine mids, they work well in that application.
Used only during testing.
Chrome 4 bar grill for 10" subwoofer $15 shipped
New condition
Homebuilt ported box for 2 6.5" ED subs $30 picked up
Not tuned, just built off the top of my head with the proper airspace requirements for the subs.
3/4 mdf, edges routed, sprayed with texture paint. Looks awesome. You will need to add wires and cut it on the end for the terminal cup. Includes a 4 bar black 15" sub grill that I modified to fit the box, it looks awesome.
4ea Memphis Audio Y's $15 shipped
They are 1 female to 2 males
5ea RadioShack Y's $15 shipped
2 of them are 1 female to 2 males, 3 of them are 1 male to 2 females...one is chrome and the others are gold plated
I also have a single new 6.5" ID OEM grill if anybody needs it. Just pay shipping
Photobucket decided to scramble the order of my pictures, so I've titled them all...You'll just have to scroll to find what you want to see. No biggie. Sorry for the hassle...
I don't have pics of the tweeters yet, they're at my parent's house...
PICS ARE HERE: car audio for sale pictures by joolay22 - Photobucket
Post a pic up of those Diamond Audio tweets. I have the 1" aluminum dome tweet too and I marketed it as such, but it was the Diamond Hex tweet out of their $250-$300 comp kit.
I'll add pics in a sec...these aren't the Hex series...I bought them and they came in a separate box by themselves, I think they were the DT3 or DTK3 or something like that. I also have a pair of the DTK1's, but they're 3/4 format. The ones I have for sale have the crossover/capacitor built into the wires.
fast306stang
fast306stang
Byron, Ga
fast306stang
