KS1000.1
$345 Shipped/Insured
24dB lowpass crossover with 30Hz to 250Hz
Master/Slave control
Variable Sub Sonic filter
Variable Bass Boost
Fan cooling
Concealed connections and controls
Power output RMS @ 4 ohms: 1 x 850 watts
Power output RMS @ 2 ohms: 1 x 1000 watts
Power output RMS @ 1 ohm: 1 x 1000 watts
Transient Distortion (400W): Frequency Response: 20Hz - 250Hz
Signal to Noise Ratio (A wtg.): >112dB
Bass Boost: +15dB@10-125Hz
Crossover (Butterworth): 30Hz - 250Hz variable 24dB
Fuse: 30A x 2
Size: 15.0 1/2"(L) x 8.0"(W) x 2 3/8"(H)
KS 300.4
$295 Shipped/Insured
Fully adjustable high pass and low pass crossovers
Crossover range 55Hz-5.5KHz
18dB bass boost @45Hz
Low radiated noise for clean AM/FM reception
Stable to two ohms stereo
Very high damping factor
Optically isolated mosfet power supply
Can drive highly reactive loads
Protection against: reverse voltage, over voltage, speaker short, and thermal overload
Power output RMS @ 4 ohms: 4 x 90 watts
Power output RMS @ 2 ohms:4 x 175 watts
Power output RMS @ 4 ohms bridged: 2 x 350 watts
Transient Distortion (100 watts): Frequency Response: 20Hz - 20 KHz
Signal to Noise Ratio: >95dB
Bass Boost: +18db@45Hz
Crossover (Butterworth): 55Hz - 5.5 KHz variable 12dB
Fuse: 30A x 3
Size: 13.0"(L) x 8.0"(W) x 2 3/8"(H)
MSRP: $399.00 each
http://i7.photobucket.com/albums/y290/mobeious/DSC01641.jpg[/img
Variable Bass Boost
Fan cooling
Fuse: 30A x 2
KS 300.4
Fuse: 30A x 3
MSRP: $399.00 each
