(2) Alipne MRD M1000
subzero
ALPINE MRD-M1000
USED FUNCTIONAL
500RMS @ 4OHMS
1000rms @ 2OHMS
UNDER RATED!
TOTAL DIGITAL CONTROLS.
AMAZING AMPS
$300 SHIPPED PER AMP.
I have 2 R2D2-10s 500 watts each dual voice cone 2ohm subs. Would this be a good investment for my need Some?
Sent from my iPad using Tapatalk
I have one amp left. it would push both your subs if they are D2 coils. d2 = 1ohm per sub, in series with the other sub = 2 ohm final load. and these amps are under rated. so you would likely be getting about 500 to 7oo rms to each sub
Gut-busting power and exacting control — that's what you get with Alpine's V12 AccuClass-D mono bass amplifiers. These unique amps convert the incoming signal to digital format, process the information, and then convert the signal back to analog at the output stage. The result — more clean power with more control!
The MRD-M1000 amplifier feeds your 4-ohm sub with a massive 500 watts RMS (1,000 watts with a 2-ohm load). Its built-in digital signal processor controls Bass Engine® features with surgical precision, giving you a level of fine-tuning capability previously found only in Alpine receivers:
you can adjust the subsonic filter from 15-50 Hz (in 5 Hz steps) to eliminate ultra-low bass which your sub wastes energy trying to reproduce;
you can use the digital parametric EQ (which allows you to control the width of the equalization curve, as well as the center point) to improve overall sound;
you can fine tune time correction, phase, and 3-level bass compensation to maximize the quality of your bass.
The Bass Compensator uses Alpine's MediaXpander (used in their receivers to optimize playback of compressed media files) to enhance low-end definition of the amplifier's output. Monitor the temperature, voltage, and current levels using the digital readout.
Alpine's digital technology ensures extraordinary clarity. The efficient Class-D design lets your music sound like thunder without wasting a lot of energy as heat, while the lightning-fast MOSFET power supplies keep your music roaring with life.
The MRD-M1000 has a set of preamp outputs for easily getting signal to another amplifier. The extra-large gold-plated wiring terminals will let your bass really hit, since larger-sized power and speaker wires let the power move more efficiently into and out of the amp.
Details:
500 watts RMS x 1 at 4 ohms
1000 watts RMS x 1 at 2 ohms
MOSFET power supply and output stage
STAR Topology for cleaner sound
Bass Engine® features:
low-pass digital crossover, 30-200 Hz, 24 dB/octave
variable subsonic filter (15-50 Hz in 5 Hz steps)
parametric EQ variable from 30-160 Hz, ±12 dB
Bass Compensator enhances low-end definition (3 settings)
top-mounted digital control center with cover
time correction 0-10 milliseconds in 0.1ms steps
phase adjustment 0-180°
turn-on delay
digital readout
detachable front cover
blue power LED
preamp inputs and outputs
outboard fuse holder with 80-amp fuse
requires 4-gauge power/ground leads and an 80-amp fuse — wiring and hardware not included with amplifier
extra-large gold-plated terminals
21-5/8"W x 2-11/16"H x 10"D
subzero
subzero
Chandler, AZ
subzero
