2 18" Omegas in an Explorer
Maybe you should have done port up in this one. You don't have enough space from the port to the back hatch. I have a 00 mountaineer and its loudest 8-10 inches away from the hatch vs 4 or 5.
I have a 94 explorer, hoping to get 2 aq hdc3 18's. Is it possible to build the box up and over the wheel wells in the back? I want the box to be as low and back away from the hatch as possible. The box has to be around 12 cubes net. If I built a box over the wheel wells (wide up top and narrow at the bottom) Will that mess up the sound?
the lows in this truck are awesome with more power the truck will definatly break shi t .
maybe you should start now by removing the sliding cover for your sunroof because that thing already moves alot with just little power.
One Bad MOFO
Turbo Fox
One Bad MOFO
FÜCK Location
DB-Audio
