2 12's vs. 1 18 pros and cons
Ok, here is what i would do.
Get the 1 18,
Why? Because then you can spend the money saved from the other sub on more power since 18" sub can usually take more power,
So get the 18 and call it a day bro
This thread sucks
With that 18, a single motor is running far more cone area, which means that you won't have to run as much power to push it to similar output levels. Assuming it's the same model subwoofer and the box is staying at a similar tuning, it should sound similar. You car may react differently to the 18, however. There's quite a few factors that will affect the way it sounds and how loud it gets.
Get the 1 18,
That's true for a select few drivers that use a different motor for the 18, but most subwoofer models use the same motor for all sizes. Take a look at the DP 10 vs 21.
solo X 18" ? //content.invisioncic.com/y282845/emoticons/phatyo.gif.0c0e21b4fcf7bc51bc9a8375a5ca4d49.gif
X2 bad *** sub... makes u feel tiny next to it... better get a huge amp tho... plus i heard these work well in a "small" enclosure when i say small i mean of course small for an 18.
its really funny to see people try and calcualte cone aress.
for example, 18" subwoofer dont have 18" cones. they are genearlly 18.5" from the edge of the basket.
the cones are closer to 16" tops.
take a tape, measure from the outside of the surround to the inside of the surround on the other side... this is a close... slightly over aprox. of the active cone area... for an 18 is about ~0.11 square meters for a given high excursion driver.
for a 12" is about ~0.049 square meters for a given high excursion driver.
18's generally have more cone area than two 12's, but we're forgetting a critical piece of information.
its not about displacement, its about sensitivity, For a 12" woofer, takes its sensitivity number and add 3dB two it every time you double down...
for example if our 12 pulls 86dB, then two pull 89 and four pull 92.
this is because we are doubling the cone area and then of course halving the current to each driver. It winds up being a +6 -3 tradeoff or net 3dB.
You also have to consider than 2 twelves prolly have better thermal proprieties than a single 18" with only 1 voice coil so in theroy ytou might be able to run te 12's with more power.
But the 18 might have a displacement advance which will come in handy in the low octaves... its just not so simple.....
sensitivity, displacement and power handling, you just look at any one.
good explanation.
Civic_boi334
Civic_boi334
Montgomery Al.
kovemaster559
