i discovered these 18's because someone told me about them on another forum in doing some research they are pretty well made and do what a good job for the price... http://video.snoopdan.com/reviews/mach5.htm heres a link to a review on the sub with termlab test results, also a video check it out...i can get 2 of these 18" subs for 188 shipped to my door. hard to beat that price....i just dont know if i should get them over fixing my blown 12L7 i had 2 12L7s one blew and if i were to keep the setup id have to get a new one around $200+. i had the kickers in a ported box using 1000+ watts at 2 ohms and they hit nicely....down side to these 2 18's is that their 8 ohms, if i got 2 of them id prob be putting them in a sealed box since im limited on space in my trunk and i wont be able to make a big enough box to make it worthy of porting(so i think), and id only be able to put them to 787@4ohms which one do you think would be louder....the 2 kicker 12L7s at 1000@2ohm or these two 18" mach5's at 787@4ohm??
here are the specs of both the subs i know little about the t/s parameters...maybe someone can explain the differences between the specs and why one is superior to the other. thanks!
Mach 5 18
Power Handling: 600 Watts
SPL (2.83v/1m): 93.4 db
Impedance: 8 Ohms nominal
T/S parameters:
Fs = 30.4 Hz
Re = 7.2 Ohms[dc]
Qt = 0.35
Qes = 0.39
Qms = 3.41
Mms = 219.3 grams
Rms = 12.3 kg/s
Cms = 0.000100 m/N
Vas = 243.8 liters
Sd= 1029.22 cm2
Bl = 27.625095 Tm
ETA = 1.07 %
Xmax = 12mm
Diameter= 36.20 cm
Kicker 12l7
T/S parameters:
Spl 1w/1m 87.4
Displacement, cc 2475
Displacement, culn 151.0
Mounting depth 6-13/6
Revc 3.62
VC inductance, mH 3.88
Sd, SqM .0645
BL 16.353
Vas, liters 68.755
Vas, CuFt 2.43
Mms, gms 223.1
Fs 31.2
Qms 10.319
Qes .593
Qts .561
Pmax, watts 750
Xmax, mm 13.20
Mach 5 18
T/S parameters:
Fs = 30.4 Hz
Re = 7.2 Ohms[dc]
Qt = 0.35
Qes = 0.39
Qms = 3.41
Mms = 219.3 grams
Rms = 12.3 kg/s
Cms = 0.000100 m/N
Vas = 243.8 liters
Sd= 1029.22 cm2
Bl = 27.625095 Tm
ETA = 1.07 %
Xmax = 12mm
Diameter= 36.20 cm
Kicker 12l7
T/S parameters:
Spl 1w/1m 87.4
Revc 3.62
Sd, SqM .0645
BL 16.353
Vas, liters 68.755
Vas, CuFt 2.43
Mms, gms 223.1
Fs 31.2
Qms 10.319
Qes .593
Qts .561
Pmax, watts 750
Xmax, mm 13.20
