12" 2XL d4
Subs are fresh recones - $145shipped/sub
subs specs
• Power Handling Capacity (Peak) : 900W
• Power Handling Capacity (RMS) : 450W
• Nominal Impedancel : Dual 4 ohm
• Voice Coil Size : 2.5"
• Frequency Response : 26Hz - 450Hz
• Sensitivity : 92 dB/W/M
• Motor Structure : 280 oz
• Mounting Depth : 6.75"
ASA-800.2
Amp is brand new - $160shipped
Amp specs
• 4 ohm Power : 200W x 2
• 2 ohm Power : 400W x 2
• 4 ohm Mono Power : 800W x 1
• Peak Power : 1600W
• Total Harmonic Distortion :
• Frequency Response : 20Hz - 22,000Hz
• S/N Ratio : >94 dB/W/M
• Damping Factor : >150
• Input Sensitivity : 0.5 - 4.0 volts
• Crossover Slope : 12 dB
• High-Pass Crossover Freq : 40Hz - 250Hz
• Low-Pass Crossover Freq : 40Hz - 250Hz
• Variable Subwoofer EQ : 0/+18 dB
• Subwoofer EQ Frequency : 40Hz
subs specs
ASA-800.2
Amp specs
