Sold 2 12" mtx jackhammer jh4512
audiobahnfan
im selling a pair of brand new mtx jackhammer series woofers im asking 100 bucks plus shipping
heres some stats on the sub
When you put the name JackHammer on any subwoofer, you've got a reputation to protect. Designed and engineered in the U.S.A., JackHammer subwoofers are made of high quality materials and are packed with features that put other subwoofers to shame.
The JackHammer series are loaded with features that make them rock. Both models feature rubber surrounds that are stitched directly to the cone for durability and have voice coils that are wound with "High Temperature" wire to ensure that your JackHammer subs will keep pounding the streets as long as you want them to. Both levels also feature MTX's proprietary Spider Plateau Venting technology which helps push hot air out of the voice coil and bring cool air in, adding to the reliability of the subwoofer and keeping it cool even in the hottest cars. JackHammer series subwoofers also feature the Asymmetrical Linear Drive System that is featured on other MTX subwoofers which combines a flat progressive spider with an extended pole piece to reproduce smooth, linear motion for incredibly crisp, clean sound.
The JH45 subwoofers have a silver stamped basked, rubber magnet cover and a industrial-looking "riveted" dust cap design.
12" JackHammer 45 Round Series Subwoofer
Power Handling:
Peak: 500 watts
RMS: 250 watts
Impedance: Single 4 Ohm
Polypropylene woofer cone
Rubber surround
Stitched Cone for added durability and style
Precision Stamped Basket for greater structural integrity
FEA optimized roll geometry to maximize excursion without sacrificing cone surface area
ALDS Asymmetrical Linear Drive System with a flat progressive spider and extended pole piece for smooth, linear, piston like drive
Industry leading thermal power handling using "High Temperature" Voice Coil Wire
Industry leading Spider Plateau Venting cooling system cools at the voice coil
1-3/4" Single voice coil
70oz. Magnet structure
Frequency response: 31-150 Hz
Sensitivity: 86.7 dB
audiobahnfan
audiobahnfan
Nebraska
audiobahnfan
