(2) 12" Critical MASS Shallow Mount subs
CerwinVega_Fan
Coolest Member
2 12inch Shallow mount CRITICAL MASS SUBS
This is the lightest, shallow mount, high power handling woofer of its kind. With power handling exceeding 1000 Watts, you simply can’t find any competition for this subwoofer. Designed to work in both extremely small sealed and small vented enclosures, this woofer has something to offer everyone. Accurate, powerful, and thin, the LS series boasts over 12mm of Xmax. Critical MASS engineering at its best!
TECHNICAL INFORMATION:
Speaker Size : 12"
Voice Coil : 3"
Max Power Handling : 1800 W
RMS Power Handling : 1000 W
Fs : 29 Hz
Znom : 2 Ohms
Linear Xmax p-p : 25.4 mm
SPL : 93 dB/2.83V
Motor : NEO
FEATURES :
Thin Mount Design:
Allows for custom shallow depth box designs.
Lightweight Design:
Weighs up to 66% less than most other High Power Subwoofers.
Huge NEO Motor structure:
Up to 20 times more magnetic charge than standard magnets.
Huge 3" Multi Layer Voice Coil:
More than 3 times the power-handling of other shallow Depth Woofers.
Multiport Vented Motor structure:
Increased Long term power handling.
Inverted Motor structure:
Further increases long term power handling and allows for shallow mounting depth.
Woven Carbon/Glass Fiber Cone:
Increased Power to Weight ratio.
Designed for Ultra small Sealed and small vented Boxes:
.75 qft (requires 1000W for full output)
1.0 qft (requires 800W for full output)
1.25 qft vented at 50 Hz (requires 400W for full output)
$950 Shipped
Sub enclosure is not included.
CerwinVega_Fan
Coolest Member
CerwinVega_Fan
Dallas,TX
CerwinVega_Fan
