LOCATED IN FORT WORTH, TEXAS
Needs work.. Does run and drive but dies at a stop. Almost positive it is a vacuum leak somewhere. Axel back exhaust was stolen. Comes with a cat, test pipe, and full straight pipe exhaust. You will need an axel back muffler portion. Also included is a B18B1 intake manifold with gasket. Planned on installing this and re-doing the vacuum system in hopes that was indeed the problem.
Replaced the timing belt, water pump, spark plugs and wires, distributor cap and rotor, O2 sensor, and installed a header.
Motor was pulled from an auto teg at 89k (B18A1). Car is a 5spd manual. Been sitting in my driveway for almost 2 years.. I'm not even the least bit motivated to work on it. If I do and fix the issue price will go up.
$1700
Clean title in hand
Not in the picture is the DC Sport intake.
Pass fender is dinged.. I've got a spare set of both fenders for the car in mint shape.
$1700
Clean title in hand
