BassHead99
I was just wondering which setup you think would get louder? 2 18" Fi Qs or 2 15" L7s. Thanks for the input guys.
Why?Umm, Q's. No question.
I agree with your first statement.Why?
L7's are a more spl based sub and Q's are more sq/sql based.
The Q's also only a bit over 50 in^2 more cone area.
I think it would be close.
so ur Qs were louder then ur L7s? what size if so?I agree with your first statement.
I am not sure how you got the numbers in the second? I couldn't locate actual cone area numbers from Kickers site, please let me know if you know where to get them. Kicker does make the claim that the L7 has a cone area between 16-20% larger than a comparable size woofer. I will take that as fact as I couldn't locate the specific information. A typical 15" driver is 810. 810x20%=162. Adding the 810+162=972. Since we are looking at a pair subs I multiply by 2=1944cm^2. This would be your sd of the Kicker L7 15"s. Next the Q's. 1210x2=2420cm^2 for the Q18's. The difference is much larger than you have figured, . I state this to find out how you obtained your numbers.
The only way it would be close is to under power the Q's and put them in an improper enclosure.
My assumption in my first post was that both pairs of subs would be given at a minimum rated power and a well built enclosure.
I will tell you that I am a Kicker fan. Have been since I was in middle school. 1989 if you must know. I recently purchased an amp from them and will continue to use their products. IMHO it is a solid company with solid offerings. I have also had a similar experience with Fi and happened to prefer as well as get better results than I did with my L7's. A) I try and share my experiences with products with others, and B) I have the math handy to back up what I propose.
Hope that explains my position well enough. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
EstimationI agree with your first statement.
Ah, ok. I don't think the L7 15" is 15"x15" though. I could be wrong. I wish someone would chime in and inform me. //content.invisioncic.com/y282845/emoticons/graduate.gif.d982460be9f153bb54e5d4cb744f6ae8.gifEstimation
Took the area of the Fi's minus the area of the Kicker's (assuming a 15X15 square)
