1600watts/Brahma
mikechec9
ok. so, i know that you only really need about 800 watts to effect xmax. and that 1600w is merely a thermal rating.
problem- my two VGA 1600.2 are all i have to work with. the brahmas are 2ohm dvc. so its either 400w/sub or 1600w/sub.
i spoke w/adire tech support, and they suggested .75 ft^3, obviously because of the power that i am using, and the whole "protect the sub from reconing, warranty" issue.
i want to know if i can safely run these subs in 1.5ft^3 with gains adjusted. and will this effect the best low end extention/output for a sealed enclosure.
fyi. i have 0/1 big 3, iraggi 220 (170) amp alt, rux/pxa 701 and strongly considering a kinetic 2400. installing the end of the month. thanks.
mikechec9
mikechec9
Chicago/Atlanta
DBfan187
